Mike
Rep Power: 10 ![]() |
Is it possible to deform all FFD control points by a specified amount (i.e. a unit deformation in y) to visualise whether they are set up correctly and properly mapped to the geometry. I think it might be possible using the SU2_DEF command but I cant figure out what options to set in the .cfg file, Cheers, M. |
Max
Mike,
Yes it is. After setting up the FFD box and creating the new mesh with the FFD information, you need to create a new .cfg. In this .cfg, for the DV_KIND option, there must be one entry of "FFD_CONTROL_POINT", separated by commas, for every control point you want to move. There must also be the same number of entries with the appropriate format, separated by semicolons, for DV_PARAM. The last three numbers of the DV_PARAM entries specify the scale of the movement in the x, y, or z direction. Next, under DV_VALUE, a displacement must be input for each point, separated by commas. Finally, DEFINITION_DV should contain an entry for all of the points you wish to move, where the last three numbers indicate the movement constraints. ex.(0,0,1) means movement only in z. Max |
control point, ffd, su2, visualisation |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
Total Deformation Vs Directional Deformation in Ansys Structural | rsdsaurav | Structural Mechanics | 0 | June 20, 2015 06:03 |
Sharp mesh deformation at FFD intersection | RonSwanson | SU2 Shape Design | 1 | May 9, 2015 08:02 |
[blockMesh] error EOF in blockMesh | Ahmed Khattab | OpenFOAM Meshing & Mesh Conversion | 7 | May 17, 2012 00:37 |
