Home > Forums > Software User Forums > SU2 > SU2 Shape Design
How do I use surface_adjoint.csv correctly?
Like Tree2Likes
  • 2 Post By jack1980
Old   November 5, 2015, 19:52
Default How do I use surface_adjoint.csv correctly?
Jouke de Baar
jack1980 is on a distinguished road
I'm trying to get adjoint based sensitivities for my design parameters, however, I would like to use self-defined shape deformation basis functions.
To do so, I deform the mesh "by hand", then run the direct solve and adjoint solve. I thought I should then be able to compute the sensitivities from the information in surface_adjoint.csv. This is my first attempt for a deformation on the top of the wing (I should probably take into account that 'senstop' is normal to the surface later):
data = np.loadtxt( 'surface_adjoint.csv' , skiprows = 1 , delimiter = ',' )
xtop = data[102:-1,6]
senstop = data[102:-1,1]
return np.trapz( senstop*basisfunction(xtop) , x = xtop )
This seems to give the sensitivity, up to a (negative) factor. What am I doing wrong here?
Thank you for your help!
Kemas_Zack and Tongtong1919 like this.
jack1980 is offline   Reply With Quote
basisfunction, sensitivity
interFoam running blowing up sandy13 OpenFOAM Running, Solving & CFD 2 May 5, 2015 08:16
how to set correctly the porosity properties to use porousInterFoam? cramsdead OpenFOAM Running, Solving & CFD 5 December 10, 2014 04:43
Viscosity-related ODE not solved correctly in a Taylor-Couette flow mk1 OpenFOAM Running, Solving & CFD 0 July 15, 2014 05:24
motorBike tutorial won't run correctly with 2.2.x Dan_Sobien OpenFOAM Running, Solving & CFD 4 September 6, 2013 05:33
[ICEM] Procedure : how to mesh correctly two semicircles in an air flow ? eeesprit ANSYS Meshing & Geometry 2 April 10, 2011 16:14
