Home > Forums > Software User Forums > SU2 > SU2 News & Announcements
New Tutorial: turbulent flow in a pipe bend with wall functions
Like Tree1Likes
  • 1 Post By bigfootedrockmidget
Old   January 27, 2023, 06:56
Default New Tutorial: turbulent flow in a pipe bend with wall functions
bigfoot
bigfootedrockmidget is on a distinguished road
A new tutorial has been placed online, explaining the setup of a simulation for the turbulent incompressible flow in a 90 degree pipe bend using wall functions:
https://su2code.github.io/tutorials/Inc_Turbulent_Bend/
More information about turbulence modeling with wall functions in general and with SU2 can be found in the presentation given at the SU2 conference:
https://www.youtube.com/watch?v=x6PMfacKuK8&t=743s
Let us know about your experience!
bigfootedrockmidget is offline   Reply With Quote
Old   June 29, 2023, 14:42
Julian Gonzalez
savedjuli is on a distinguished road
Thanks for your hard work on including the possibility of using wall functions. I do have a doubt, that maybe you can shed some light on it.
I'm running some cfd analysis for a comercial transport aircraft; the complicated cases are for the high Mach numbers, i.e. transonic, and high angles of attack, I need to develop the lift curve up to stall.
I have a very fine mesh, that computationally is very heavy, so takes a lot of time to run; I'm not obtaining the expected results, or even for the really high Mach numbers, I'm not even obtaining convergence; so I was wondering, if I use the wall functions capability, so I can use thicker layers for the boundary layer mesh, so y+ won't be ~1 (like te current one) but bigger, would that help on the convergence issue, and in obtaining accurate results in less time?
Thanks!
savedjuli is offline   Reply With Quote
Old   June 30, 2023, 04:03
bigfoot
Yes with wall functions you could use for instance y+=30. But please check the paper of nichols and nelson (2005) for applicability. If you have flow separation the wall model results will not perform very well. But I guess it is better than having no results. Still, it might be good to see if you can make the wall resolved case converge by improving the mesh quality or modifying the numerical settings.
savedjuli likes this.
su2, tutorial, wall functions
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
Verification of Turbulent Pipe Flow in OpenFOAM - kwSST ajcav2 OpenFOAM Running, Solving & CFD 6 April 28, 2017 16:51
3D pipe flow - Using UDF's to define fully developed turbulent flow on the inlet Taz-CFD CFD Freelancers 1 February 21, 2016 12:12
3D pipe flow - Using UDF's to define fully developed turbulent flow on the inlet Taz-CFD ANSYS 0 February 19, 2016 08:49
Flow through pipe bend tutorial - Solver Error sledfreak17 CFX 4 May 16, 2012 11:29
