Home > Forums > Software User Forums > SU2 > SU2 Installation
Error: FAILED: meson-install(during NInja installation)
Like Tree1Likes
  • 1 Post By bigfootedrockmidget
Old   December 2, 2021, 13:26
Default Error: FAILED: meson-install(during NInja installation)
DIvesh Sharma
Divesh is on a distinguished road
C++ linker for the host machine: /usr/bin/mpicxx ld.bfd 2.34
Host machine cpu family: x86_64
Host machine cpu: x86_64
Program python3 found: YES (/usr/bin/python3)
Found pkg-config: /usr/bin/pkg-config (0.29.1)
Run-time dependency MPI for c found: YES 4.0.3
Run-time dependency MPI for cpp found: YES 4.0.3
Message: Extracting boost ...
configuration....then I got this error!
:~/SU2$ ./ninja -C build install
ninja: Entering directory `build'
[721/722] Installing files.
Installing SU2_CFD/src/SU2_CFD to /usr/local/bin
Installation failed due to insufficient permissions.
Attempting to use polkit to gain elevated privileges...
Error getting authority: Error initializing authority: Could not connect: No such file or directory
/usr/bin/python3 /home/divesh/SU2/meson.py install --no-rebuild
ninja: build stopped: subcommand failed.
can anyone guide me to solve this?
I am new to python and SU2 both.
Divesh is offline   Reply With Quote
Old   December 3, 2021, 13:02
bigfoot
bigfootedrockmidget is on a distinguished road
you are not allowed to install in /usr/local/bin, probably because you run this as a regular user and you need admin rights for global installation. If you install as a regular user, you usually install in your home directory, you give the installation directory to meson by adding --prefix=/home/userdir/su2 to your meson command.
ugurtan666 likes this.
bigfootedrockmidget is offline   Reply With Quote
ninja installation failed
Ansys Installation on Docker Container mohsen.shiea ANSYS 11 March 14, 2024 12:18
Ninja and Meson installation for SU2 AeroEnthusiast SU2 Installation 0 March 2, 2021 21:59
[foam-extend.org] A smooth installation of foam-3.0-extend on OpenSUSE 13.1 64-bits cookcaptain OpenFOAM Installation 7 May 26, 2015 12:22
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
