SU2 paralllel Build from source ninja failed on ubuntu 18.04 |
July 4, 2020, 10:40 |
Rep Power: 6 |
Hello everyone
I wrote what I have done in order. 1.I want to SU2 built from source.I performed "./meson.py build".I think it was successful shown in mesonpy_outputs.png After that, I specify SU2 Paths in my .bashrc with export. 2.However , "/.ninja -C false install" fails after "/.meson.py build operation. Shown in ninja_error_screen.png Could you help me on this problem ? (I use Openmpi for parallel) Thanks in advance |
July 4, 2020, 13:52 |
Pedro Gomes
Rep Power: 13 |
It should be ./ninja -C build install (there's a little bug causing "false" to be printed).
build is the name of the configuration directory specified when calling meson.py. From the output you posted, ninja will try to install SU2 in /usr/local/bin, you will need root privileges for that (i.e. sudo ninja ...). Alternatively you can specify a different installation directory using meson option --prefix="/some/path/" |
July 4, 2020, 13:54 |
Rep Power: 6 |
Thanks I will try
July 4, 2020, 14:23 |
meson py failed now
Rep Power: 6 |
Thanks pcg
I install openmpi and ubuntu again due to some problems. Now, when I run meson.py I faced with python library error. Shown in meson_py_python_problem.png I have installed python-dev,numpy,scipy before performing meson.py. Apart from these Moreover, I would like to emphasize if I'm gonna use "sudo apt install python3-pip" to install some missing libraries . There will be python error occurring something like old version.I tried that solution and it has not worked . I also give meson.py log error txt file meson-log.txt Could you help me again ? |
July 4, 2020, 18:21 |
--prefix error
#5 | |
Rep Power: 6 |
I performed what you say in terminal but it gives error. I prefer to use --prefix so I created a new directory. However, I get errors shown in meson_py_prefix_error.png Thanks in advance for your interest |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
