March 27, 2017, 06:38 |
Error building version 5.0.0 on cluster
Hi all,
For some reason SU2 will not compile on our cluster, with some issue with metis, which seems weird since it came with SU2, but maybe I am overlooking something? Previously we had version 4.2.0 running on the same cluster, all I did was git pull, configure and tried make, which failed with the error output below: Code:
/usr/bin/ld: gk_cur_jbufs: TLS reference in ../../externals/metis/libmetis.a(libmetis_a-kmetis.o) mismatches non-TLS definition in ../../externals/metis/libmetis.a(libmetis_a-error.o) section .data ../../externals/metis/libmetis.a: could not read symbols: Bad value collect2: ld returned 1 exit status make[1]: *** [../bin/SU2_CFD] Error 1 make: *** [all-recursive] Error 1 Regards, Tom |
March 31, 2017, 12:46 |
Tim Albring
Rep Power: 11 |
Hi Tom,
have a look here: https://web.archive.org/web/20150319...?part=1&chap=3 you can try adding the flag using: export CXXFLAGS="$CXXFLAGS -fPIC" before running the configure script. |
April 2, 2017, 12:56 |
First it did not work, but I just had to make clean and run make again, and now it works! Thanks a lot. Best regards, Tom Last edited by tomf; April 2, 2017 at 13:03. Reason: Spoke too soon |
OpenFOAM on cluster: version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found | ovie | OpenFOAM | 10 | April 19, 2021 19:06 |
simpleFoam convergence issue | Harnoor | OpenFOAM Running, Solving & CFD | 13 | November 16, 2016 09:23 |
[OpenFOAM.org] openfoam-2.2.0 installation on cluster of Redhat 4.1.2-48 | Chandler | OpenFOAM Installation | 32 | June 10, 2015 13:53 |
How can i uninstall new version of OF | shipman | OpenFOAM Installation | 5 | August 12, 2013 05:01 |
version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found | ovie | Main CFD Forum | 1 | April 19, 2010 15:00 |
