January 19, 2014, 06:18 |
SU2 3.0 build failure
Rep Power: 17 |
Hi all,
Recently I intended to install SU2 3.0 from source (git ver.) but failed to build. Any informations are highly appreciated. My environment is as belows: CentOS 6.5 x86_64 cmake 2.8.12.1 (from source) metis 5.0.2 (from source) cgnslib 3.1.3-4 (from source) mpicxx (mpich2 from system) Configure and output lines are : $ ./configure --prefix=/usr/local/SU2 --with-CGNS-lib=/usr/local/cgnslib/lib --with-CGNS-include=/usr/local/cgnslib/include --with-Metis-lib=/usr/local/metis/lib --with-Metis-include=/usr/local/metis/include --with-Metis-version=5 --with-MPI=/usr/bin/mpicxx [snip] Build Configuration Summary: Source code location: /home/waku/SU2 Install location: /usr/local/SU2 Version: 3.0.0 "eagle" Compiler: /usr/bin/mpicxx Preprocessor flags: Compiler flags: -g -O2 Linker flags: CGNS support: yes MPI support: yes Metis support: yes TecIO support: no Mutation++ support: no Build SU2_CFD: yes Build SU2_DDC: yes Build SU2_GPC: yes Build SU2_MAC: yes Build SU2_MDC: yes Build SU2_PBC: yes Build SU2_SOL: yes Build SU2_GDC: yes Build SU2_UMC: yes --------------------------------------------------------- $ make Making all in Common/lib make[1]: Entering directory `/home/waku/SU2/Common/lib' /usr/bin/mpicxx -DPACKAGE_NAME=\"SU\^2\" -DPACKAGE_TARNAME=\"SU\^2\" -DPACKAGE_VERSION=\"3.0.0\ \"eagle\"\" -DPACKAGE_STRING=\"SU\^2\ 3.0.0\ \"eagle\"\" -DPACKAGE_BUGREPORT=\"susquared-dev@lists.stanford.edu\" -DPACKAGE=\"SU\^2\" -DVERSION=\"3.0.0\ \"eagle\"\" -I. -I/usr/local/cgnslib/include -I/usr/local/metis/include -DMETIS_5 -DNO_TECIO -DNO_MUTATIONPP -g -O2 -MT ../src/libSU2_a-geometry_structure.o -MD -MP -MF ../src/.deps/libSU2_a-geometry_structure.Tpo -c -o ../src/libSU2_a-geometry_structure.o `test -f '../src/geometry_structure.cpp' || echo './'`../src/geometry_structure.cpp ../src/geometry_structure.cpp: In member function 'void CPhysicalGeometry::Read_CGNS_Format(CConfig*, std::string, short unsigned int, short unsigned int)': ../src/geometry_structure.cpp:1450: error: 'ZoneType_t' was not declared in this scope ../src/geometry_structure.cpp:1450: error: expected ';' before 'zonetype' ../src/geometry_structure.cpp:1451: error: 'DataType_t' was not declared in this scope ../src/geometry_structure.cpp:1451: error: expected ';' before 'datatype' ../src/geometry_structure.cpp:1454: error: 'ElementType_t' was not declared in this scope ../src/geometry_structure.cpp:1454: error: expected ';' before 'elemType' ../src/geometry_structure.cpp:1567: error: 'zonetype' was not declared in this scope ../src/geometry_structure.cpp:1621: error: 'datatype' was not declared in this scope ../src/geometry_structure.cpp:1625: error: 'datatype' was not declared in this scope ../src/geometry_structure.cpp:1625: error: 'RealDouble' was not declared in this scope ../src/geometry_structure.cpp:1673: error: 'elemType' was not declared in this scope ../src/geometry_structure.cpp:1687: error: 'elemType' was not declared in this scope ../src/geometry_structure.cpp:1694: error: 'elemType' was not declared in this scope ../src/geometry_structure.cpp:1695: error: 'NODE' was not declared in this scope ../src/geometry_structure.cpp:1699: error: 'BAR_2' was not declared in this scope ../src/geometry_structure.cpp:1703: error: 'BAR_3' was not declared in this scope ../src/geometry_structure.cpp:1707: error: 'TRI_3' was not declared in this scope ../src/geometry_structure.cpp:1711: error: 'QUAD_4' was not declared in this scope ../src/geometry_structure.cpp:1715: error: 'TETRA_4' was not declared in this scope ../src/geometry_structure.cpp:1719: error: 'HEXA_8' was not declared in this scope ../src/geometry_structure.cpp:1723: error: 'PENTA_6' was not declared in this scope ../src/geometry_structure.cpp:1727: error: 'PYRA_5' was not declared in this scope ../src/geometry_structure.cpp: In member function 'virtual void CPhysicalGeometry::SetColorGrid(CConfig*)': ../src/geometry_structure.cpp:5023: error: cannot convert 'int*' to 'idx_t*' for argument '1' to 'int METIS_SetDefaultOptions(idx_t*)' ../src/geometry_structure.cpp:5025: error: cannot convert 'int*' to 'idx_t*' for argument '1' to 'int METIS_PartMeshNodal(idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, real_t*, idx_t*, idx_t*, idx_t*, idx_t*)' make[1]: *** [../src/libSU2_a-geometry_structure.o] Error 1 make[1]: Leaving directory `/home/waku/SU2/Common/lib' make: *** [all-recursive] Error 1 Thanks in advance waku2005 |
January 20, 2014, 23:51 |
Rep Power: 17 |
Hi all
I solved the above build failure. SU2 works now ! What I did are as follows: 1) Change variables derived from CGNSlib like "BAR_2" to CGNS_ENUMV(BAR_2) 2) Add "-L/usr/lib64 -lhdf5_hl -lhdf5 to the $(CXXLIB) line in SU2_*/obj directories. Regards waku2005 |
January 23, 2014, 12:42 |
Rep Power: 12 |
Hello guys,
I have a similar problem but I did not understand what I have to do. I would very much appreciate some help. Thanks I get this message: ../src/geometry_structure.cpp:5027:34: error: cannot convert ‘int*’ to ‘idx_t* {aka long int*}’ for argument ‘1’ to ‘int METIS_SetDefaultOptions(idx_t*)’ ../src/geometry_structure.cpp:5029:102: error: cannot convert ‘int*’ to ‘idx_t* {aka long int*}’ for argument ‘1’ to ‘int METIS_PartMeshNodal(idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, idx_t*, real_t*, idx_t*, idx_t*, idx_t*, idx_t*)’ make[1]: *** [../src/libSU2_a-geometry_structure.o] Error 1 make[1]: Leaving directory `/home/ju/Documents/SU2/Su2_v3/Common/lib' make: *** [all-recursive] Error 1 Regards, JuB |
January 24, 2014, 05:52 |
Rep Power: 17 |
Hi JuB
This is my diff file. I hope it helps you. Best regards waku2005 |
January 24, 2014, 13:40 |
Rep Power: 12 |
Hello waku2005,
It worked! Thanks a lot! Regards, JuB |
Official release of SU2 V3.0 and SU2 Educational V1.0 | fpalacios | SU2 News & Announcements | 2 | January 22, 2014 06:28 |
SU2 suite has moved to GitHub! | fpalacios | SU2 News & Announcements | 0 | August 12, 2013 03:07 |
System Build Advice for FEA | cycleback | Hardware | 1 | February 8, 2013 21:53 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 03:48 |
OpenFOAM-1.6.x PV3FoamReader build failure. | aunola | OpenFOAM Installation | 2 | September 5, 2009 09:22 |
