Home > Forums > General Forums > Structural Mechanics
Rope Explicit Analysis
Like Tree1Likes
  • 1 Post By calim_cfd
Old   January 12, 2023, 01:22
Default Rope Explicit Analysis
Mayank Shakya
Mayank Shakya is on a distinguished road
Hello
I am trying to simulate the behavior of rope used in road barriers. Can we use 1D element to reduce the mesh size. If it is possible what properties should be assigned to the 1D element so that it behaves like actual rope.
Please suggest some ideas.
Thank and regards,
Mayank
Mayank Shakya is offline   Reply With Quote
Old   January 16, 2023, 09:57
Thumbs up
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
Originally Posted by Mayank Shakya View Post
Hello
Thank and regards,
Mayank
Hi.
First of all, check what accuracy you actually need for the response of this rope..but regardless, theoretically, you need the constitutive and/or phenomenological behavior of your rope.. then you need a 1-D element which accepts this material model and finally set a non-linear analysis... if it needs to be static or transient, it depends on your problem.
Good luck
Mayank Shakya likes this.
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
ansys
Analysis of rotating fan in room in ansys fluent harianshu FLUENT 0 April 10, 2016 15:01
Implicit vs Explicit analysis? cyrusIII Main CFD Forum 9 April 6, 2016 11:03
Lateral Analysis Centrifugal Pump laltenburg ANSYS 0 January 11, 2016 09:54
Modelling the cross aisle direction of a steel selective rack for model analysis m8rix ANSYS 0 September 20, 2011 11:28
LES post analysis faisal_durr Main CFD Forum 0 July 13, 2011 06:52
