Home > Forums > General Forums > Structural Mechanics
Simulation isn't converging
Like Tree1Likes
  • 1 Post By Lara Gonçales
Old   February 12, 2020, 14:08
Default Simulation isn't converging
Lara Andressa Ordonhe Gonçales
Lara Gonçales is on a distinguished road
I'm having difficulties to converge my simulation in the "Static Structure" and I don't know what else I can do.
I am simulating a deformation in the artery wall after simulating the blood flow in the Fluent. I am doing this through the "one way" method. So, I imported the pressure in "Static in the Structure" and started the simulation here, but it doesn't converge. The simulation stops in time 0.4 seconds.
I tried to refine the mesh (with an element size of 0.001 m), but nothing changed. I don't know if the property of the wall (density, isotropic, Yeoh equation) can interfere in convergence.
Can someone help me?
WilliamWoles likes this.
Lara Gonçales is offline   Reply With Quote
Old   February 13, 2020, 05:08
karachun's Avatar
karachun is on a distinguished road
Any pictures, error messages, models? Without additional information no one can help you. First of all it is good to tell what FEA package do you use.
karachun is offline   Reply With Quote
Old   February 13, 2020, 10:22
Here is the image of the simulation result: https://imgur.com/cKj8GbS
I'm using ANSYS 19.1
I think the problem is the geometry I'm using
Old   February 13, 2020, 11:16
karachun's Avatar
Maybe, I cannot tell anything without geometry. Convergence difficulties are very common, they may be caused by zillion of reasons.
Some additional pictures descriptions (mesh type, mesh quality, boundary conditions, loads, material properties) will be fine.
Old   February 28, 2020, 10:24
Hey!
Last week, I tried to simulate again, but all the models did not converge. I don't know if the problem is the models or some incorrect configuration.
I have some images here about each setting.
https://ibb.co/6P7S6nv
https://ibb.co/Tg75wgG
https://ibb.co/FsQpHZj
https://ibb.co/B6gt8J3
https://ibb.co/F4WVHsz
https://ibb.co/mywDTZK
Old   March 10, 2020, 04:06
karachun's Avatar
Ok, but I still dont undersatnd - is this solid mesh or plate. If solid then try to reduceelement size - look like element size is bigger than wall thickness.
And try to reduce applied force. If force too big then any mesh will be distorted until solver diverge.
artery, blood flow, one-way coupling
Some questions about flow boiling simulation in Fluent beastieboys6 FLUENT 8 November 21, 2017 00:47
Direct simulation converging but not the Adjoints amrit38 SU2 1 November 17, 2016 18:59
Simulation not converging (core dumped) jet_engine OpenFOAM Running, Solving & CFD 2 May 25, 2016 09:31
Flat Plate: Simulation is not converging Luana.M. OpenFOAM Running, Solving & CFD 1 April 14, 2016 02:14
Control simulation to apply different fields with chtMultiRegionFoam jmdf OpenFOAM Running, Solving & CFD 0 February 29, 2016 08:05
