problem in importing force-time data from excel into ansys |
Deepak Yadav
Rep Power: 0 ![]() |
I'm doing a simulation in transient structural in workbench 17.1, when I try to import force-time history from excel-2010 into workbench using .XML files, it is showing that 'either the specified location is incorrect or the source at that location contains no data'. So can somebody please give me the solution of this problem.
Thanks |
#2 | |
Rana Nasser
Rep Power: 9 ![]() |
Rana Nasser
transient-acc in put2.jpg transient-acc in put3.jpg like the attached pictures I use Windows Copy and Paste to put acceleration-time history into an acceleration load in Transient Structural. Someone sent me this method and I found it works. |
Gwenael H.
Rep Power: 20 ![]() |
There are some issues when you try to import or even with copy / paste sometimes. When you use the copy/paste be sure to select the 1st cell of the table as Nasser showed otherwise partial paste could occur.
You can also take advantage of the external data module to import .txt / .csv files but unfortunately you can’t define acceleration directly but displacement and velocities are supported. |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
AnSYS Icepak - defining a report solution, problem (time steps) | chris92jc | ANSYS | 0 | August 17, 2015 11:33 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Importing 3D data as CEL into ANSYS CFX 11.0 | Dave W. | CFX | 9 | October 19, 2007 08:18 |
