September 17, 2017, 04:46 |
Ansys Workbench Beam & Shell element
Joseph
Rep Power: 9 |
Hi everyone,
I have looked everywhere and read heaps of docs but I could not find an answer to this. For someone it is probably a very simple fix. Your help will be greatly appreciated! So, I used design modeler to draw a system of beam and shell elements as shown (in the attachments). It's a net system. The frame and the outer poles are all modeled as beams (different cross-sections) whereas the ball and the net itself are surfaces. I am using explicit dynamics. Now, to the problem. As you can see in the results (Von-mises equivalent stress), only the stress results of the surfaces are shown. But what i really want is the stress (bending) results in the pole and the frame. (Beam stress tool is not even available to choose so I could not try other beam specific solutions) Help please! cheers!! |
September 18, 2017, 09:51 |
Stuart
Rep Power: 26 |
This part of the User Guide (help/wb_sim/ds_probes_structural.html) says stress on bodies using probes in explicit dynamics. Not been able to get it to work though and a test gives the warning "No stress/strain results are found on beams. Please set the Beam Section Results to Yes" but haven't found that option.
After a bit more searching in Solution / Post Processing you can set Beam Section Results to Yes and this activates the stress / strain contours and probes. Last edited by siw; September 19, 2017 at 03:17. |
September 19, 2017, 06:12 |
#3 | |
Joseph
Rep Power: 9 |
When you click "Solution" under "Explicit Dynamics" tree, there is "Calculate Beam Section Results". However, when i run the solution with this option on, I get a warning message "Beam Stress/Strain results are reported in solution coordinate". So it seems the solution is there somewhere. But I still can not retrieve the results. The fault is probably with my approach. But defining path as well as using probe were not successful. (I get 0 stress results with the probe) |
September 19, 2017, 06:32 |
Stuart
Rep Power: 26 |
The option I said above is a mistake, so leave it off you just need to make User Defined Results from the Worksheet with STRAIN_1 for beam strain and BEAM_MISES_STR for beam stress.
September 19, 2017, 06:52 |
#5 | |
Joseph
Rep Power: 9 |
CHEERS!!! it worked! So I am guessing BEAM_MISES_STR is an equivalent of Von-mises? |
[ANSYS Meshing] How to change element type in Ansys Workbench | vpvmech | ANSYS Meshing & Geometry | 2 | April 6, 2018 10:46 |
Shape function for beam element | Kim yongchul | Structural Mechanics | 0 | February 3, 2017 07:20 |
Analysis of shell and tube heat exchanger in Ansys | Dena | FLUENT | 0 | June 12, 2015 13:39 |
Problem when modeling Arch Bridge by Ansys Workbench 14.0 | tranhoa279 | ANSYS | 0 | August 30, 2013 01:29 |
Export Heat Flux CFX -> ANSYS Workbench | Freeman | CFX | 2 | April 11, 2010 08:24 |
