ANSYS - Stress tools are not available while working with beam |
May 22, 2014, 04:25 |
Sam Ha
Rep Power: 12 |
Hi there,
Could any one help me? I want to analysis an steel structure, and I need the result is Equivalent von-Mises stress. But the stress tools are not available (please the picture) The way I create the model is: create 2 point and make a line from them, then I assign cross section to the line, pls see the picture Could you show me the problem here? Thanks a lot!! Pic1.jpg Pic2.jpg |
May 22, 2014, 16:36 |
Rep Power: 13 |
From the screenshot, it seems you are in the Geometry module. Once you are ready to go with your geometry, you need to go back to workbench project schematic and open the model module.
I strongly suggest that you read the Workbench User's Guide before any further step. |
May 22, 2014, 20:05 |
Sam Ha
Rep Power: 12 |
Thanks Alex,
I've got the answer. Close topic! |
June 19, 2018, 21:58 |
Matheus Lima
June 20, 2018, 08:17 |
Stuart
Rep Power: 26 |
First, set Beam Section Results = Yes. This is in Mechanical / Outline / Solution / Details / Post Processing.
Then use the options in the Beam Tool and the User Defined Results for models with 1-D line bodies. |
September 3, 2018, 05:01 |
no post processing in details tab
#6 | |
Rajasthan
no post processing in details tab .pls help |
How to view the stress on the structure in Ansys Static Structural? | SteveFinnan | ANSYS | 0 | April 13, 2014 02:44 |
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation | Volker P. | ANSYS Meshing & Geometry | 22 | January 17, 2012 17:27 |
comsol cantilever beam problem | bhu47 | COMSOL | 0 | June 30, 2008 14:59 |
Intelbs MPI and performance tools in OpenFOAM | hplum | OpenFOAM | 16 | December 16, 2007 14:58 |
Compressible Reynolds Stress Models | cosimobianchini | OpenFOAM Running, Solving & CFD | 0 | August 24, 2007 06:13 |
