Home > Forums > Software User Forums > Siemens > STAR-CD
Fuel injection table in ES-ICE
Like Tree2Likes
  • 1 Post By Arunkumar_ice
  • 1 Post By abhayminachi
Old   March 5, 2017, 08:32
Post Fuel injection table in ES-ICE
Arunkumar Dhanapal
Arunkumar_ice is on a distinguished road
Hello everyone,
I am using STAR CD (es-ice) to carry out a FULL CYLINDER CLOSED-CYCLE SIMULATION using diesel oil as fuel using 6 hole injector (each holes at two different planes - 3 holes in one plane & other 3 holes in another plane below the first plane). I am ready with the closed cycle polymesh for my engine geometry. To move further with the pre-processing, i am struck with the injection table which needs to be specified for each injector holes. My doubts are
1. What are the parameters that the fuel injection table consist over X-axis and Y-axis ?
2.Will I be able to get a simple injection profile by carrying any theoretical calculation with the known parameters below?
I have the engine speed (2400 rpm), mass of fuel injected per cycle (58.9 mg/cycle) , injection duration (23 CA deg), fuel injection timing (8 deg bTDC), injector hole diameter (0.206mm), Injection pressure (260 bar), inlet air pressure at BDC (1.2 bar) and other data related to engine and injectors.
Please help me out with this. Thank you so much in advance. Your help will be very much needful for me.
Thanks & Regards
Arunkumar
abhayminachi likes this.
Arunkumar_ice is offline   Reply With Quote
Old   April 19, 2017, 14:58
abhayminachi is on a distinguished road
Hi
Fuel injection table constitutes fuel mass on y axis n timing/duration on X axis.
Also
For the time being u can use a constant fuel profile else u can have trapezoidal profile by simple mathematical calculations, so that 58.9 mg is injected over the specified duration.
Thank u
Sent from my Lenovo A6020a46 using CFD Online Forum mobile app
Arunkumar_ice likes this.
abhayminachi is offline   Reply With Quote
Old   April 20, 2017, 05:23
Arunkumar Dhanapal
Hi Abhay,
Thank you so much for your explanation, Abhay.
Regards,
Arunkumar
injection problem Mark New FLUENT 0 August 4, 2013 02:30
UDF for fuel injection djokovic Fluent UDF and Scheme Programming 0 July 1, 2010 16:49
fuel injection Johannes P. Siemens 6 February 19, 2009 09:45
case stops when fuel injection starts Antony Siemens 1 August 7, 2005 14:42
injection of fuel into tank filled with fuel mujahid FLUENT 1 February 19, 2004 07:36
