Jason
Rep Power: 15 ![]() |
Hi All,
Is it possible show a example code of iso-surface from the transient data (*ccmt), such as temperature, species concentration (CO2, OH, etc)? It will be great, if you could add some explanation of the commands. Also, how to know the which number indicates the piston surface, if I would like to show the concentration only on piston surface? refer to the following code. !Collect the piston surface data into a cell set ctable, 502, fluid vset, newset, edge cset, newset, surface, 263919 cmodify, cset .. .. .. .. !Plot cell-averaged fuel scalar data on the piston surface getcell, conc, 1 cset, newset, type, 502 caverage, cset poption, cont cplot Thank you in advance. |
#2 | |
zheng jianjun
Rep Power: 16 ![]() |
you can try these commands,
bset newset region 6 ! see Define boundary|Define boundary region panel vset newset bset getw,... cset newset vset all cset subset shell caverage, cset poption, cont wplot ... OR bset newset name region1_piston_crown vset newset bset getw,... cset newset vset all cset subset shell caverage, cset poption, cont wplot Quote:
#3 | |
Jason
Thank you very much for the help. It works perfectly.
Any idea about the iso_surface plot??? ![]() Quote:
Pauli
Rep Power: 17 ![]() |
popt, isos, value
where value is the numeric value for the isosurface |
Jason
Pauli
Enter the command "help popt" & read the results.
popt sets the plotting option isos reguests an iso-surface value is the vaule of the iso-surface I believe you need to have vertex data loaded before you create an iso-surface. If you don't understand what I mean by vertex data, read more of the manual. Then use the getv command to load the data you want to view. So: getv vmag popt isos 40 cplo would give you an iso-surface for velocity magnitude 40. Or you can click a bunch of stuff in the Nav-Center.... |
#7 | |
Jason
Thank you very much for the explanation.
![]() btw, what is the nav-center?? research institute?? company? or cfd group? Quote:
Pauli
Sorry, the Nav-Center is the old name for what is now labeled pro-Star Model Guide.
Plot Data from Probes | owayz | OpenFOAM Post-Processing | 23 | February 4, 2016 08:18 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 11:52 |
plot trisurface sampling data in 3d | mihaipruna | OpenFOAM Post-Processing | 1 | May 1, 2013 16:38 |
recording data from the XY plot | Karan | Main CFD Forum | 0 | February 1, 2009 19:47 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
