calculation stops and BICGStab did not converge
Like Tree1Likes
  • 1 Post By siara817
Old   March 5, 2012, 21:38
Default calculation stops and BICGStab did not converge
Xiao Liu
vandermessi is on a distinguished road
When I try to run the calculation, it failed and the output is as below, who has met this problem and solved it?
BiCGStab did not converge !
* CFL 5.00000e+00 -> 5.00000e-01...
A floating point exception has occurred: floating point exception [Invalid operation]. The specific cause cannot be identified. Please refer to the troubleshooting section of the User's Guide.
Command: RunSimulation
CompletedCommand: RunSimulation
In: [Machine::main, SimulationIterator::startSimulation, SteadySolver::step]
error: Server Error
vandermessi is offline   Reply With Quote
Old   March 6, 2012, 04:19
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
I had this problem, and it was because of the mesh quality. check the cell quality by Threshold. Find the worst cells. choose the Cell quality remediation model in the Physics models. Also you can right click on your regions and remove the low quality cell if they are few.
good luck
aniramzee likes this.
siara817 is offline   Reply With Quote
bicgstab, floating point exception
