simulating wing motion of an insect???
Like Tree1Likes
  • 1 Post By ping
Old   January 18, 2012, 00:25
Default simulating wing motion of an insect???
sanjay's Avatar
aerosapien
sanjay is on a distinguished road
Hi, I am trying to simulate the motion of a insect wing (uniaxial motion i.e just rotation) in CCM+. I have selected the following physical conditions.
Morpher
3 dimesnsional
implicit unsteady
constant density
segregated flow
gas
turbulent
K-epsilon model
Can nay one tell me how to specify motion for the wing.
regards
www.aerosapien.blogspot.com
sanjay is offline   Reply With Quote
Old   February 13, 2012, 03:17
Ping
ping is on a distinguished road
simple next step - create a field function which specifies the rotation velocity of the wing as a function of radius - eg using a sin function and a local cylindrical coordinate system. then for the wing change morpher setting to grid velocity and apply the field function.
we are promised overset mesh is version 7.02 coming soon and this will make this case faster to solve since the morpher adds another set of equations to solve.
sanjay likes this.
ping is offline   Reply With Quote
Old   February 13, 2012, 04:27
sanjay's Avatar
aerosapien
thanks for the reply, Il work on it and get back for more discussion
regards
Old   February 16, 2012, 09:41
Ryan Coe
ryancoe is on a distinguished road
You could also create a field function, as ping suggests, but use the rotation and translation motion module to move the entire domain. This would be less computationally intensive than morphing the mesh.
Ryan
Ryan
ryancoe is offline   Reply With Quote
Old   February 18, 2012, 08:26
abdul099 is on a distinguished road
Ryan, he needs to morph the mesh since not all of the domain will rotate. Just the wing will do the rotation while the body won't.
Sanjay, you can also directly apply a motion as boundary condition for the morpher. That's much easier than creating a field function specifying the grid velocity etc.
I agree to ping that overset mesh (once it's released, should be at beginning of march) will be a better approach, since morphing sometimes needs much more computing time than the flow solver and needs a significant amount of memory, especially on big meshes.
abdul099 is offline   Reply With Quote
Old   February 18, 2012, 10:54
Ryan Coe
Didn't realize there was a body involved. Good catch!
Ryan
Old   March 6, 2012, 02:53
sanjay's Avatar
aerosapien
thanks a lot for those replies.
I decided that I will first do 2D simulation of flapping and then go for 3D
Can any one tell me how to create the flapping in 2D
regards
Old   May 11, 2012, 07:44
alireza
alireza_b is an unknown quantity at this point
Hi
Dear users.
I write a UDF for flapping wing for fluent and compiled it and dont have any problem.
But i can not use dynamic mesh?
can you help me.
1- in gambit creat a zone aroud airfoil and implement a interface boundary condition.
2- in fluent i use define-interface
3- enable dynamic mesh with layering and smoothing.
4- selected airfoil and use UDF.
But airfoil is fixed and dont move!
albeit:
fluent have this error:
cg motion is incorrect.
alireza_b is offline   Reply With Quote
Old   May 11, 2012, 18:40
alireza_b, this is the star-ccm+ forum.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
Simulating Particle motion in tube using UDF alib022 Fluent UDF and Scheme Programming 6 March 27, 2017 05:49
Flapping Wing motion balkrishna FLUENT 19 April 13, 2016 16:42
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
CEL code for simulating the equation of motion of a vibrating rigid body mohamadaliv CFX 11 October 19, 2011 05:30
simulating bacteria motion doctsh Main CFD Forum 0 July 31, 2009 11:29
