Difference between MRF and RBM
Like Tree3Likes
  • 2 Post By sail
  • 1 Post By abdul099
Old   January 11, 2012, 06:06
Post Difference between MRF and RBM
Clerk
Clerk is on a distinguished road
Hi Everyone, I am new to Star CCM+, What is the difference between moving reference frame and rigid body motion. Except the difference like moving mesh in RBM(unsteady), stationary in MRF(steady).May i know what are all the other difference.
Clerk is offline   Reply With Quote
Old   January 12, 2012, 17:16
Ladnam is on a distinguished road
I will give this a try.
In MRF the different bodies are fixed in position but the fluid feels the forces as if the bodies were moving. This will often be good enough for axisymmetric geometry.
Ladnam is offline   Reply With Quote
Old   January 12, 2012, 17:56
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
in rigid body motion the reference system stays still, and the domain/flow/mesh is moving.
in mrf, as the name suggest, the entire system is moving. because this method is less computationally expensive than the rbm, it is successfully used in, for example, rotating parts, turbiles, isolated propeller analysis (in case of a rotation)
saleh alsubari and ank86it like this.
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Old   August 12, 2012, 23:45
saleh
saleh alsubari is on a distinguished road
hi ...
do u know how to use reference frame in turbine analysis
need to know ,the turbine RPM given the mas flow rate as input
thanx
saleh alsubari is offline   Reply With Quote
Old   August 21, 2012, 23:39
sail's Avatar
Vieri Abolaffio
Originally Posted by saleh alsubari View Post
hi ...
thanx
sorry to disappoint you, but I belive that to get the rpm you'll need to use the RBM tecnique
Old   August 21, 2012, 23:45
saleh
thanx for replying ...
can u plz elaborate ,about RBM techinqes cuz i have not used that one so far...
thanx a gain
Old   August 28, 2012, 20:49
abdul099 is on a distinguished road
I'm sorry I have to disagree. It's just a matter of accuracy and computing time whether to use RBM or MRF. You'll get a (less acurate) result using MRF, but it might still be better than a bad RBM result.
saleh alsubari likes this.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
mrf, rbm, star ccm+
