June 19, 2011, 07:02 |
simple porblem
Rep Power: 15 |
Hi All,
I want to change the erosion rate from kg/m^2-s to mm/ year or or m/ kg. can anyone help?? Thanks in advance. Regards, alan |
July 5, 2011, 09:15 |
Adrien Lemoine
Rep Power: 15 |
Hi Alan,
mm/ year = density(kg/m3) * kg/m^2/s / (3600*1000) (check the units one more time to be sure) Adrien
------------------------------------------- Plz add reputation if the answer is correct A cœur vaillant rien d'impossible ------------------------------------------ |
June 4, 2015, 07:10 |
Ayush Jain
Rep Power: 11 |
Hi AdrienL,
I am also modelling erosion in star ccm+ but my concern is I am trying to simulate one of the experimental results. Problem is experiment was done 24 hrs as geometry will be keep on changing and every 2hrs author took reading of erosion in mm/year. How can I model for such a long time please suggest PS: Using morphing we can change the geometry based on the erosion rate |
SIMPLE algorithm in 3D cylindrical coordinates | zouchu | Main CFD Forum | 1 | January 20, 2014 17:02 |
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | November 10, 2010 01:47 |
Making SIMPLE converge faster | Fabio | Main CFD Forum | 4 | April 9, 2006 11:35 |
PISO vs. SIMPLE | benedikt flurl | Main CFD Forum | 2 | April 14, 2005 06:54 |
flow over a 2D cyl using SIMPLE | T | Main CFD Forum | 1 | January 27, 2001 07:32 |
