March 16, 2011, 17:16 |
Ahmed Body on 25degree
Hello everyone,
I am an undergraduate who is doing a ahmed body with 25degree. This is the first time that I use a CFD software. I have a question about the residual plot when you start running the report. The Tdr line starts going up and down when iteration start from about 150+. May I ask is there any problem to do with the model or mesh? Here is my setting: inlet velocity: 40m/s turbulence intensity: 0.5% surface mesh: polyhedral mesher, prism layer mesher and surface remesher physics: constant density, gas, k-epsilon turbulence, realizable k-epsilon two layer, reyonlds-average navier stokes, segregated flow, steady, three dimensional, turbulent and two layer all y+ treatment. where the base size of the mesh is 100mm and mesh in the body is min: 1mm and target: 5mm. The floor and the wall is in slip condition. There are 4 prism layers around the body which is 1mm thick, growth rate: 1.2 Please help me out. Thanks |
March 17, 2011, 16:28 |
Vinicius Girardi
Rep Power: 17 |
In which order of magnitude it is oscilating?
March 22, 2011, 09:16 |
Rep Power: 22 |
I expect the flow to seperate from the body, producing some vortices behind the body. That may be a reason for the osscillation, as you are running this case in steady state.
What are the other residuals looking like? And the forces on the body? Cheers |
August 18, 2011, 07:35 |
Girish Gaikwad
Rep Power: 16 |
try using trimmer mesh...
[GAMBIT] Ahmed Body 3D mesh | Saima | ANSYS Meshing & Geometry | 19 | February 10, 2018 12:59 |
Ahmed Body | andrea.pasquali | OpenFOAM | 10 | June 18, 2016 04:16 |
Drag over Ahmed body | Shamoon Jamshed | FLUENT | 2 | May 18, 2009 15:15 |
Can't get good results on ahmed body research | Michael | Main CFD Forum | 8 | September 17, 2008 14:55 |
aerodynamic of Ahmed body | VORTEX | FLUENT | 1 | August 7, 2006 21:48 |
