creating velocity inlet profile on star ccm+
Like Tree2Likes
  • 2 Post By loreaero
Old   May 26, 2009, 14:06
Default creating velocity inlet profile on star ccm+
Lorenzo
loreaero is on a distinguished road
hallo ,
i'm an italian student and i've some problems with star ccm+.
i need to create a velocity log law profile but i don't know how to compile a field function. i 've tried to create some function component and to assemble these on vector one with no results.
i add my attempts:
i've tried to introduce the z variable with $$Position[2]
u(z) component definition:
((0.164696691/0.4)*log(($$Position[2]+5.32267E-05)/5.32267E-05*0.866)-3.084
v(z) component definition:
-(0.164696691/0.4)*log(($$Position[2]+5.32267E-05)/5.32267E-05)*0.5
help me please
thanks a lot
loreaero is offline   Reply With Quote
Old   May 27, 2009, 04:37
Maddin is on a distinguished road
In my ccm the z variable is "Position_2" and to use them I make $Position_2
/edith says: Often the field function is only shown when you had "used" them in a scene, don't know why but I only have the "Position"-Vector, when I used the scalar displayer Position -> Laboratory -> Z, I have the field function Position[Z].
I hope it helps you.
Maddin is offline   Reply With Quote
Old   May 27, 2009, 06:14
pad
PA
pad is on a distinguished road
I actually did something similar with a power-law profile based on a desired flow rate where I used several field functions to calculate Re, exponents etc.
If you are using a cylindrical boundary (e.g. a pipe) you might find it easier to define a local cylindrical coordinate system (placed in the center of the inlet) and then use
$$Centroid(name_of_your_cylindrical_coordinate_sys tem)[0]
$$Centroid(name_of_your_cylindrical_coordinate_sys tem)[1]
$$Centroid(name_of_your_cylindrical_coordinate_sys tem)[2]
to calculate the velocity based on the distance from the center of this CS.
Consult the manuel regarding the details of the x, y, z of the cylindrical coordinate system.
Hope this helps a bit...
pad is offline   Reply With Quote
Old   June 8, 2009, 10:55
Default thanks very much at all
Lorenzo
thanks very much at all!! i've solved my problem
i don't understand why, but starccm+ don't love number squared...and on my first expression i've digited ^2 and not the simple number result.
well! if you need to simulated a velocity profile for an atmospheric boundary layer, the best way is to write the log law in component like what i've do and to create a field function velocity where put the component expression.like this
[((0.164696691/0.4)*log(($$Position[2]+5.32267E-05)/5.32267E-05)*0.866)+3.084 , -(0.164696691/0.4)*log(($$Position[2]+5.32267E-05)/5.32267E-05)*0.5 ,0]
thanks again
good luck at all
Juan_Ca and FOWT like this.
Fully developed 3d velocity profile: Square inlet! Taru FLUENT 6 September 14, 2015 09:38
How to apply velocity profile at inlet Sam CFX 12 April 1, 2012 07:52
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
velocity more than INLET velocity neu FLUENT 3 May 13, 2003 05:56
