star-ccm Directed meshing
Like Tree1Likes
  • 1 Post By technoB
Old   December 11, 2023, 21:58
Default star-ccm Directed meshing
McVas
technoB is on a distinguished road
Hi There,
I am trying to use star-ccm+ to generate a radial polar cylindrical mesh for a circular cylinder with directed meshing. I used the cylinder surface as the source surface, and outer concentric surfaces of the circular domain as the target source. The mesh generated is as below. The issue is at the source mesh, the radial grid does not align with other concentric layers as shown in ogridzoom.png attached. Does anyone have a solution for this, or is there an additional step that may be of use?
(I have also attached a reference mesh as ref_mesh)
Thank you in advance
technoB is offline   Reply With Quote
Old   December 12, 2023, 16:19
McVas
I sorted this out using an appropriate patch mesh if anyone had a similar problem. It appears i had complicated the thought process
ian0103 likes this.
cylinder domain, directed mesh, meshing, star ccm+, structured mesh
Fluent vs Star CCM vs Openfoam EthanWalker ANSYS 3 November 4, 2023 08:54
Error while importing Solid Works Model into Star CCM Sandy7 STAR-CCM+ 3 December 19, 2016 12:21
Change the Mass flux formulation in Star ccm Xuekun STAR-CCM+ 0 January 24, 2016 09:14
Problem in PERIODIC BC in STAR CCM mohammad STAR-CCM+ 7 January 28, 2015 10:38
error in star ccm maurizio Siemens 3 October 16, 2007 06:17
