Porous Media - Evaluation of the porous intertial/viscous resistance
Like Tree1Likes
  • 1 Post By Filippo_azz
Old   November 14, 2023, 05:57
Question Porous Media - Evaluation of the porous intertial/viscous resistance
Julien
Twinsen_cfd is on a distinguished road
Hello everybody,
I would like to model the flow along a complex geometry with : cross section changes, obstacles, tubes bundle etc...
I started to evaluate different values of region's porosity and set a porous media model in order to obtain "real velocities" (ie flow acceleration due to cross section reduction).
My question is : how can I fill the porous inertial and viscous resistance tensor in order to model the real pressure drop across the domain ?
Thanks in advance for your answers !
Twinsen_cfd
Twinsen_cfd is offline   Reply With Quote
Old   December 11, 2023, 14:13
Filippo Azzini
Filippo_azz is on a distinguished road
Hi, to obtain that value you have 2 different strategies that you can adopt, the first one is to evaluate the pressure drop dp/dx from experimental measures at different velocities, and the second one is to do the same bit numerically, starting form the real geometry.
In both cases you need to perform the simulation for different velocities, to obtain a curve dp/dx vs. V.
Then with a linear or polynomial regression, you can evaluate the constant C1 and C2 (namely viscous and inertial terms ).
Best,
Filippo
Twinsen_cfd likes this.
Filippo_azz is offline   Reply With Quote
Old   December 12, 2023, 10:51
Julien
Hello Filippo,
Thank you very much for your clear and concise answer.
Twinsen_cfd
inertial resistance, porosity, porous media model, pressure drop, viscous resistance
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Porous Media Zone Thickness TheKitchenCleaner FLUENT 0 October 5, 2020 01:42
viscous resistance and inertial resistance of porous media Weiqiang Liu FLUENT 1 June 15, 2020 07:26
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
How to define the porous inertial resistance and viscous resistance of porous media? pinfan143 STAR-CCM+ 5 July 21, 2015 12:52
