Rep Power: 0 ![]() |
Hi, I'm working on directed mesh in my project in starccm+. Surface meshes are fine, volume mesh generates between choosen surfaces, and quality of cells is acceptable. But when I'm checking random crossection of my model the surface that is generated looks poorly and I do not understand why it happens since directed mesh creates the same surface every other propagation step. Do you have any idea what is going on? Here are some screenshots of my problem.
Rep Power: 6 ![]() |
Can this be just a visualization artifact? I'd try using a Cell Surface derived part instead of a regular Section Plane and see if the cells still look strange. You can also consult this Knowledge Base article, if you have access to the Support Portal:
https://support.sw.siemens.com/en-US...00046232_EN_US |
#3 | |
#crossection, #directedmesh, #starccm+ |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
Conformal mesh between two Directed mesh | Cuau | STAR-CCM+ | 2 | January 27, 2021 05:30 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
