April 4, 2023, 17:17 |
Mesh forming additional surfaces
Rep Power: 3 |
I am attempting to simulate a car to find lift and drag etc. At the bottom of my wheel I have a small tab to avoid tight corners with the floor when meshing. However additional surfaces (highlighted purple in the images) are formed in both front and rear wheels after meshing. The problem occurs both with a trimmer and polyhedral meshes however with the polyhedral mesh, the simulation actually runs and I get Cl and Cd values. Whereas with the trimmer mesh I get the following error: "A floating point error has occurred. The following error has been logged: A non-finite residual (Tke) was added by star.keturb.KeTurbSolver. Typical causes are overflow, underflow, or a division by zero. Please check your usage and inputs." Does anyone have any idea how I can prevent the additional surfaces from forming? Thanks in advance for your time and help! Image 1.png Image 2.png Image 3.png |
April 4, 2023, 17:59 |
Matt
Rep Power: 18 |
It's a little hard to tell what's going on here. Most likely, you either have a problem with surface quality of your CAD file that is corrupting your mesh or you are running into proximity issues. You can try changing your auto-repair minimum proximity setting in your mesher controls and see if that helps.
April 4, 2023, 19:16 |
Chaotic Water
Rep Power: 18 |
On the screenshot those addisional surfacel look just like part or the tab.
Maybe try wrapping - there is a good example: https://www.youtube.com/watch?v=OGIYYLziZWI The video is a bit out of date: no more Region-based meshing and Surface Wrapper is now a separate Part Operation, but the method is still actual. |
April 5, 2023, 15:56 |
Paul Hancock
Rep Power: 17 |
If you're wrapping your geometry, car to tunnel, then I'd say that contact prevention would fix your additional surfaces. If you're not wrapping, then adding in a local refinement at the base of the tire would probably help. Perhaps both.
Your software crash problem looks similar to what I've run into. I locate, using a threshold of max velocity, where the solution is beginning to blow up. An example would be identifying cells with velocities over 1000m/s. They are typically flat pancake cells. I then remove them out of the domain, usually just one or two cells, and continue running the simulation. I've convinced myself that I really don't care about a small bump on the surface of my vehicle. It's happened enough that I've automated the process. |
April 12, 2023, 16:33 |
Rep Power: 3 |
Contact prevention fixed it, thank you very much!!
April 13, 2023, 02:49 |
Chaotic Water
Rep Power: 18 |
Option of Surface Wrapper called "Wrapper Defeature" might also help in those areas as an addition to Contact Prevention.
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 16:15 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 15:41 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
