Fire Wizard Setup - No Physics Continuum available |
Marc Ricart
Rep Power: 4 ![]() |
I am trying to simulate a fire temperature effect on a metal box above it. I have 3 regions (box, room, fire) and 2 continuas (gas and solid). When setting up the fire wizard I select the FIRE in the "turn on fire region" and the airbox outlet as "select pressure boundary" that is the exit. The I select my HRR setting but when I click apply I get the following pop-up error: "No Physics Continuum available" I have 2 continuas on the model. I don't know how to solve this problem, any idea? Thanks |
Oliver Cato
Rep Power: 0 ![]() |
I believe I have had the same problem. Try deleting the solid physics and then apply the fire settings. Then add the solid physics again. A very inconvenient issue. |
#3 | |
Marc Ricart
Yes, I think that was the issue, I managed to make it work by carefully following a fixed sequence of operations. It is a bit inconvenient but I at least it worked now. Thanks for the reply |
conduction, fire dynamic simulator, fireandsmokewizard, star ccm+, thermal analysis |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
change physics continuum option after running a steady sim with java | A.Forte91 | STAR-CCM+ | 1 | June 11, 2018 06:47 |
Different Physics Contnuum for Same Region | itsanisant | STAR-CCM+ | 0 | October 10, 2014 00:30 |
Multiple Physics Continua | boathead | STAR-CCM+ | 6 | December 4, 2011 12:33 |
physics phD to CFD? | jck87 | Main CFD Forum | 13 | October 9, 2010 16:15 |
