Averaging a field along a specific direction
Like Tree1Likes
  • 1 Post By f-w
Old   December 27, 2022, 09:02
Default Averaging a field along a specific direction
Diego
aaaaaa is on a distinguished road
Hi everyone,
I can't figure how to average a scalar field that is defined on the boundary of a body that has constant cross-section along the x direction in a way that:
1. The average is calculated for points that share the same (y,z) coordinates
-OR-
2. The average is calculated for points of the surface that share the same normal vector
I've tried using coordinate-based field function operations but can't find a solution yet, I'd really appreciate some advice. Thank you in advance.
aaaaaa is offline   Reply With Quote
Old   December 28, 2022, 00:11
f-w
f-w's Avatar
f-w is on a distinguished road
There's a way to accomplish this using the "bands" report feature, but it's limited to force and moment reports. It's ridiculous that such a capability is not built-in for any field function that has surface values, like temperature.
A true station average will require fancy post-processing in a java macro (for which I don't have time to write); however, I do have a CRUDE solution for you, which is approximate if your surface cell size is uniform.
Create a section plane perpendicular to the x-axis, at your starting station, and select the region boundaries of interest. Create an Element Count and a Sum report, and select the section plane you just created for both, and the field function of interest for the Sum report. Create and run an Expression report, defining it as the Sum report divided by the Element Count report.
Now, change the station in your section plane, and rerun the Expression report. A java macro can be created to iterate this process (and print the result to output window and/or write a file). Once again, this is a crude solution, and the result will be only approximate to the true average if your cell size is uniform on your boundary.
There might be a java macro that Siemens knowledge base or forum, or someone on this forum, posted, but I haven't seen one. If anyone cares to share or create such a macro, I could use it as well.
Cheers
aaaaaa likes this.
f-w is offline   Reply With Quote
average field, star ccm+
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Spanwise averaging of three-dimensional field Fuchs OpenFOAM Post-Processing 47 December 1, 2021 09:59
Determination of the time period for averaging of the velocity field at periodic flow mo92 OpenFOAM Running, Solving & CFD 0 December 18, 2018 13:24
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
