Time averaged velocity streamlines
Like Tree2Likes
  • 2 Post By cwl
Old   November 12, 2022, 19:29
Default Time averaged velocity streamlines
McVas
technoB is on a distinguished road
I am running an unsteady simulation on a bluff body. I want to show the time-averaged flow field using streamlines. I was able to create a monitor and a contour scene representing this. However, when trying to create streamlines it does not show the time-averaged result. The mean velocity field function is not listed as one of the options for streamline field function.
Is there a way to display the time-averaged velocity streamlines on a scene?
Thanks in advance
technoB is offline   Reply With Quote
Old   November 13, 2022, 04:00
cwl
Chaotic Water
cwl is on a distinguished road
You mean - Mean monitor?
Streamlines require vector field, so you'll need three mean monitors (of three velocity components) - and then define vector field function from them.
cwl is offline   Reply With Quote
Old   November 13, 2022, 06:43
McVas
HI,
Thanks for replying
Yes, I created a field mean monitor. But i only tried the U component.
That is actually helpful,thanks!So I have to create 3 mean monitors with respect to each velocity component, u,v,w, which would create 3 field functions. On creating the vector field function, do you know what the definition syntax would look like to bring all 3 together?
Thanks in advance
Old   November 13, 2022, 11:42
cwl
Chaotic Water
When you define vector field fuction:
- set its type to Vector in field function properties;
- syntax is:
    [<i-component>, <j-component>, <k-component>]
i-oriented unit vector would be
    [1, 0, 0]
radius-vector would be
    [$$Centroid[0], $$Centroid[1], $$Centroid[2]]
your case would be something like
    [${MeanofVelocityi}, ${MeanofVelocityj}, ${MeanofVelocityk}]
I'm not sure it would be "MeanofVelocityi" or something similar, you can check that at properties of the mean monitor (there is a read-only name of the function), or just look through the available field functions.
Islam Abdelghafar and technoB like this.
Old   November 14, 2022, 10:55
McVas
Thank you so much ,that helped
star-ccm+, streamlines, time-averaged
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 10:08
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) Scabbard OpenFOAM Running, Solving & CFD 1 July 22, 2014 05:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
