July 3, 2022, 09:33 |
Face Quality
Qais
Rep Power: 6 |
Greetings,
How do I deal with poor face quality regions? To give a better understanding of my question, I have attached a photo where the surface repair tool shows some regions with poor quality. In those regions, the mesh quality is lacking as well. How can repair those faces with poor quality? Thanks a lot! Qais |
July 3, 2022, 14:14 |
Chaotic Water
Rep Power: 18 |
It's a so-called "tesselated mesh" - i.e. triangulated representation of the geometry and it's ok for it to have "yellow" or "orange" (i just don't remember by heart what they are .. proximity .. quality?) faces.
This mesh has almost nothing to to with resulting mesh. You can improve it by right-clicking the part in the tree and selecting "Re-Tesselate". The surface represented this way is remeshed to (hopefully) good triangles representation later by the Automatic Surface Remesher which is actually used for construction of volume mesh. |
July 4, 2022, 16:24 |
Qais
Rep Power: 6 |
Thanks a lot for the reply and clarification cwl! I really appreciate it.
Please see this photo https://1drv.ms/u/s!AkCnaOk1rReF4AS2...LKacy?e=WA0SxY The automatic surface remesher is giving good quality cells in all regions except the part as shown in the attached picture (which is where the bad face quality exists). As you can see, the picture show that at certain cells the skewness angle is almost 90 deg which are really bad quality and they are also affecting the quality of the prism layers as well. I tried refining the surface mesh but the issue is not resolved. If you have any suggestions, please let me know! Thanks again, Qais Khraisat |
July 11, 2022, 20:54 |
#4 | |
Chaotic Water
Rep Power: 18 |
The link to the image doesn't work.
Try uploading it somewhere else. UPD And now the link works fine .. strange. Quote:
July 12, 2022, 05:36 |
#5 | |
Lefteris
Rep Power: 16 |
I am guessing however that you could try to refine the mesh around that leading edge (or whatever that is), allow the cells to get smaller in that part of the geometry. Also, do you think that this could cause instabilities in the solution?
Lefteris |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
[Other] Mesh quality | vitorspadetoventurin | OpenFOAM Meshing & Mesh Conversion | 0 | November 28, 2014 19:27 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
