High divergence in cfd-dem model
Like Tree1Likes
  • 1 Post By Cassian
Old   June 24, 2022, 17:57
Default High divergence in cfd-dem model
Cassian
Cassian is on a distinguished road
I'm simulating fluid (water) flow through a packed dem particle bed in a cylindrical shaped domain.
When I set BCs to either a velocity inlet or stagnation inlet with very small velocity/ pressure values with a pressure outlet of 0 psi, I notice very high flow velocities and particle velocities with correspondingly high momentum divergence.
Even if I set a stagnation inlet of 0 psi pressure and pressure outlet of 0 psi (no gravity), instead of having no fluid flow (0 velocity), I end up with super high velocities and divergence.
I'm using Coupled flow model with the Implicit unsteady solver. Flow is of constant density.
I've not found any improvements by using the Segregated flow model.
I have Two-Way coupling for Lagrangian models turned on.
My timestep is 1e-7.
I've attached screenshots of what happens during my runs, if anyone has any suggestions or insights, I would be super grateful.
Mahmoud Abbaszadeh likes this.
Last edited by Cassian; June 24, 2022 at 18:13. Reason: Adding important information
Cassian is offline   Reply With Quote
Old   March 1, 2023, 11:08
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
Hi Cassian,
Hope you are doing well.
I wonder if you can share with us the details of your simulation. I am currently simulating something similar. I want to create a packed bed and run water flow through it.
Best Regards,
Mahmoud
Mahmoud Abbaszadeh is offline   Reply With Quote
cfd-dem, divergence issues, starccm+
Divergence detected in AMG solver. VOF. Mr.Mister Fluent Multiphase 5 November 22, 2024 07:32
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
Two Phase Flow In Vertical Pipe stonepreston FLUENT 2 October 31, 2017 09:35
Dry cooler - simplified cfd model mech_01 FLUENT 0 September 23, 2017 16:00
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
