Define value of field function when it's equal to 0 |
Rep Power: 5 ![]() |
is there a way to set the value of a field function when it becomes 0? The field function f(t) is defined as: f(t) = 1/(sin(2*pi*t))^2, with t representing time. The field function becomes 0 at e.g. t = 0. Since a division by 0 is not possible I want to replace the value of f(t) when it's value is N.a.N. for example by implementing an if statement. Is there a way to realise the replacement by an if condition or by another way? |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
The answer to your question regarding if is:
if ( boolean ? a : b) returns a when the boolean is true, else returns b But the answer to your problem lies in implementation. Use a max function like so: f(t) = 1/max((sin(2*pi*t))^2,1e-10) This way you divide by 1e-10 instead of 0 when sin^2 becomes very small |
Thank you, worked perfectly!
field fucntion, if statement, time |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 09:23 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
