Surface isn't Manifold - Volume Meshing
Like Tree1Likes
  • 1 Post By Peresvet
Old   December 3, 2021, 14:55
Default Surface isn't Manifold - Volume Meshing
Bal
Bal21 is on a distinguished road
Hi everybody.
I am getting the surface is not manifold error message at the beginning of the volume mesh phase. I have tried the repair surface and it has no problems, no non-manifold edges or vertices, free edges, pierced faces etc, but I'm still getting the error....I'm working with an STL file that I can post here if it's okay.
PS im a beginner in CFD.
Thanks ,
Bal21 is offline   Reply With Quote
Old   December 3, 2021, 20:56
Smile
Peresvet
Peresvet is on a distinguished road
Originally Posted by Bal21 View Post
Hi everybody.
Thanks ,
Not all 3D modeling tools can be used if you do not want to engage in heavy repair of the model and if you did not make it in the native editor. It is much better to use .iges for insertion.
Bal21 likes this.
Peresvet is offline   Reply With Quote
Old   December 4, 2021, 01:23
Bal
Can I import .STEP? Or a parasolid file instead?
Old   December 4, 2021, 06:54
Peresvet
I did not understand the question.
You can import. I do this when the model is complex. You can also treat.
https://youtu.be/YTlFd7BbwQc
Old   December 4, 2021, 06:57
Bal
Thanks for your response. I meant which is better.. importing a .step file or a parasolid file or there's no difference..?
Attachment 87424
Attachment 87425
Old   December 4, 2021, 07:10
Peresvet
Please. If the model is made with the right tool, everything is possible.
mesh
error, non manifold error, volume mesh
OpenFOAM error Vinay Kumar V Main CFD Forum 0 February 20, 2020 10:17
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
