Switched from POD to Local license. Scripts for job que (.sh files) don't work
Like Tree1Likes
  • 1 Post By LuckyTran
Old   October 28, 2021, 09:34
Default Switched from POD to Local license. Scripts for job que (.sh files) don't work
cplatano
-Ik- is on a distinguished road
Switched from POD to Local license. The scripts for adding a job in the cluster queue (.sh files) don't work anymore.
Until now, I used the following submit.sh file:
#!/bin/sh
#PBS -N FSTD
#PBS -S /bin/sh
#PBS -j oe
/#directory/everybody/14.04.013/STAR-CCM+14.04.013/star/bin/starccm+ -power -podkey # -licpath #@flex.cd-adapco.com -batchsystem pbs -rsh rsh -mpi intel -np $PBS_NP >
I tried replacing it with the following:
<#directory/14.04.013/STAR-CCM+14.04.013/star/bin/starccm+ -server -rsh rsh -np $PBS_NP -batch Tutorial/Macros/meshandrun.java Tutorial/Simulations/tutorial.sim>
I used X11 to see the Command line in STAR and that's how I tried to replace the code (as seen in the attached picture)
Unfortunately, it doesn't work. Does anybody know how it should be replaced?
-Ik- is offline   Reply With Quote
Old   October 28, 2021, 09:53
Lucky
If all you want to do is switch from POD licensing to a license hosted (where is it being hosted) then you just change -licpath from 1999@flex.cd-adapco.com to the location of your license server.
Btw, posting your pod key onto the internet means everyone here can burn all your hours.
-Ik- likes this.
Old   October 28, 2021, 09:56
cplatano
@LuckyTran Too bad it is expired, I guess. Thank you tho!
It didn't work changing from 1999@flex.cd-adapco.com to the directory of my local license
Old   October 29, 2021, 14:26
Lucky
Not a directory... The network location. The ip address, etc.
You need to give 1999@address
The 1999 is the port the server is running on. That port number might be different for you if your network admin is running the server on a different port.
If the license is on your machine and you are trying to run this on a grid then I hope you have the license server installed and running correctly.
.sh, bash script, job queue, local license, starccm+
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
