Negative cell volume generated / SIGSEGV issue
Like Tree2Likes
  • 1 Post By LuckyTran
  • 1 Post By cwl
Old   July 3, 2021, 10:02
Default Negative cell volume generated / SIGSEGV issue
Michu
michu is on a distinguished road
Hi all,
Any advice or help would be greatly appreciated. I知 new at StarCCM+.
I知 generating negative volume cells / SIGSEGV error messages. I notice it happens when I move around to different geographical locations.
I move around a lot for work.
I create SIM_#1 in northern NY. It runs and completes the simulations fine. I then go to southern NY and when I try to open SIM_#1 I get a SIGSEGV issue which digging into was due to negative volume cells. So I clear the generated mesh, save as SIM_#2 and can run the simulation in souther NY. If I go back to northern NY, the SIGSEGV issue happens for SIM_#2 but then SIM_#1 opens fine.
Is this supposed to happen? Does StarCCM+ limit the geographical locations where you can work on files?
I知 running a simulation on a 6 core computer with 64GB of RAM
Thank you very much!
michu is offline   Reply With Quote
Old   July 9, 2021, 12:13
Lucky
That would be silly
a sigsegv happens when you try to access something that doesn't exist. What is common is that you save something and try to open something... and access... something that's not there.
This can easily happen if you've got macros not set up properly. But it could also be a million other bugs in your setup. If it's critical you should try to figure out what you did wrong or it will keep happening no matter where you go. Or, it could be the obvious, cells with negative volumes not having fluxes stored on them which are then missing when you try to open your sim later.
michu likes this.
Old   July 12, 2021, 21:34
cwl
Chaotic Water
cwl is on a distinguished road
SIGSEGV (known as "Access Violation" under Windows) is a purely a software (Star-CCM+) internal error related to accessing wrong address.
Might be avoided by not using something that causes it, but in general - it is the software developer's part of work.
michu likes this.
cwl is offline   Reply With Quote
How to resolve Negative cell volume issue in fluent? Meesm1 Fluent Multiphase 0 July 6, 2020 12:05
How to eliminate error "Update-Dynamic-Mesh failed. Negative cell volume detected" in bobdorm14 Fluent UDF and Scheme Programming 8 March 30, 2020 06:17
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 11:44
Negative Volume - apprentice madboy19 FLUENT 0 November 4, 2015 22:08
