Hydrodynamic Pressure Contour Plotting
Like Tree4Likes
  • 2 Post By cwl
  • 1 Post By ashokac7
  • 1 Post By sumon
Old   June 21, 2021, 14:02
Default Hydrodynamic Pressure Contour Plotting
Md Daluar Hussain Sumon
sumon is on a distinguished road
Dear all,
Greetings !
I am trying to plot a scene of Hydrodynamic Pressure for a simulation. I have defined the field function as , $Pressure - $Density * 9.81 * $$Centroid[2]. But this doesn't match with the experimental plotting.
I am not sure that whether it is the proper way to plot Hydrodynamic Pressure or not. or is there any other way?
Can anyone please help me to sort out my confusion?
Regards.
sumon is offline   Reply With Quote
Old   June 23, 2021, 16:21
cwl
Chaotic Water
cwl is on a distinguished road
When gravity is on - $Pressure in Star-CCM+ is actually piezometric pressure in which the second term is already considered and thus there is no need to subtract it explicitly.
Depending on what you mean by "hydrodynamic pressure" - you might try to plot Static Pressure, that might be what you're looking for.
ashokac7 and sumon like this.
cwl is offline   Reply With Quote
Old   June 25, 2021, 01:07
Smile isn't it a pressure due to velocity head
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
I think you could just subtract Static pressure from total pressure to get dynamic pressure. Let me know if this matches to the experimental values.
sumon likes this.
ashokac7 is offline   Reply With Quote
Old   June 25, 2021, 09:14
I have found the dynamic pressure subtracting static pressure from total pressure, I think it is pretty nice compared to experiment.
Thanks for your reply !
ashokac7 likes this.
Old   June 27, 2024, 09:08
Default Getting pressure contours for a rotating body in regular waves
ANAGHA S
ANAGHA S is on a distinguished road
I had made a simulation for a rotating body in regular waves. During the initial stage of run, pressure contour (using $pressure function) was showing the effects of waves and as the rotation progressed and simulation started to converge, the waves were not visible. In the end of the simulation run, I got just circular contours around the body without any impact of waves.
Could someone explain me this kind of behaviour of pressure contours?
ANAGHA S is offline   Reply With Quote
hydrodynamic pressure, star ccm+
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
