April 28, 2021, 09:10 |
Cannot evaluate field function Velocity
Rep Power: 5 |
I'm pretty new in using Star-CCM+ or in General a CFD-Software. I want to run a transient analysis where I want to implement a stopping criteria that is activated when the total kinetic energy in the system is not varying more than a certain amount anymore. For that I defined a Field Expression called Kinetic Energy per Volume, which I defined as: 0.5 * dot($${Velocity},$${Velocity}) * ${Density} Now my problem is that I receive an error message when I want to run the expression (definition is my field function) which says: Cannot evaluate field function Velocity I hope I was able to communicate my problem and that somebody is able to help me. |
April 28, 2021, 09:21 |
Chaotic Water
Rep Power: 18 |
What type is the report?
April 28, 2021, 09:23 |
Rep Power: 5 |
I used an Expression Report. It's value I wanted to use for a Volume Integral Report afterwards.
Edit: When I tried to use a Volume Integral Report in first place, I wasn't able to choose my Field Function in that kind of Report. But now it somehow worked. Nevertheless I am curious about why the field function velocity cannot be evaluated in the case of an Expression Report. |
April 28, 2021, 09:30 |
#4 | |
Chaotic Water
Rep Power: 18 |
But your Field Function is a function defined in every cell - there is no single value to be reported. So - just go agead with the Volume Integral Report and it will work fine. |
April 28, 2021, 09:31 |
Rep Power: 5 |
Thank you very much, cwl!
That makes sense. Like given. |
April 28, 2021, 09:34 |
Chaotic Water
Rep Power: 18 |
You are very welcome :>
April 28, 2021, 09:36 |
#7 | |
Chaotic Water
Rep Power: 18 |
You can always check your Field Function by plotting it on some plane section. If it is not available there - then check Field Function definition itself. |
expressions, field function velocity, field functions |
Define periodic velocity profile by field function at the inlet | uhlondon | STAR-CCM+ | 4 | June 24, 2017 04:07 |
User Field Function - Velocity Vector | Vitor_Manuel | STAR-CCM+ | 2 | May 7, 2017 18:03 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
