Scaling CFD Results by Mach Number
Like Tree1Likes
  • 1 Post By Shah Akib Sarwar
Old   March 21, 2021, 10:47
Default Scaling CFD Results by Mach Number
Shah Akib Sarwar
Shah Akib Sarwar is on a distinguished road
I am currently trying to solve a problem using Star-CCM+ that involves gas exiting a nozzle at high velocity and hitting the ground. The aim is to find the temp/pressure values on the point where the gas hits the ground (stagnation point). The Mach number at nozzle exit is 5. However, beyond Mach 3, the solver runs into convergence issues due to temperature anomalies (temperature exceeds the maximum allowable value of 5000K). I am using steady, coupled flow, coupled energy, k-omega-SST models for the solution. As I am fairly new to CFD and Star-CCM+, any suggestions on how to solve this issue would be greatly appreciated.
Also, if there is any analytical way to scale the results I got for Mach 3 to Mach 5 (even if it is a rough estimate), that would be of great help too!
Thank you.
Peresvet likes this.
Shah Akib Sarwar is offline   Reply With Quote
Old   March 26, 2021, 06:47
Peresvet
Peresvet is on a distinguished road
Thank you.
If the program could easily cope with such tasks, then hypersonic weapons would not only be ours. Moreover, you are just learning. In such tasks, the designer should be more cunning than cfd.
To be honest, inside the current generator you can decide anything, but not what came out of the supersonic nozzle at GREAT Mach numbers. You can only adjust the solution to the practical result, and this is a secret program.
Sorry.
Peresvet is offline   Reply With Quote
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 14:05
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 11:11
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
