Changing pressure at boundary conditions
Like Tree1Likes
  • 1 Post By cwl
Old   February 1, 2021, 22:12
Default Changing pressure at boundary conditions
Joseph
jseamon1 is on a distinguished road
Hello All,
I am running a simulation of water flowing through a pipe of small diameter (321 micrometers). The boundary conditions I am using for my inlet and outlet are a Stagnation Inlet of 4000 Pa and a Pressure Outlet of 0 Pa, respectively. As I run the simulation, my outlet pressure remains constant, but the inlet pressure dives from 4000 Pa to 2900 Pa (see attached picture). As I understand it (and I may be completely wrong), the boundary conditions should remain constant throughout the simulation. Does anyone have an explanation of why it may be dropping? Also, is there a better way to apply a constant pressure at the inlet? Thank you all so very much for your help!
jseamon1 is offline   Reply With Quote
Old   February 2, 2021, 13:45
cwl
Chaotic Water
cwl is on a distinguished road
Stagnation Inlet imposes Total Pressure, i.e. your 4000 Pa = Static Pressure + ρ·vē/2.
So as velocity develops at inlet - part of 4000 Pa is "stolen" for Dynamic Pressure (ρ·vē/2) and Pressure that you monitor is the remaining Static Pressure term in your case (it is actually piezometric pressure in general).
You can check that by monitoring Total Pressure function at the inlet the same way - it should be 4000 Pa.
jseamon1 likes this.
cwl is offline   Reply With Quote
Old   February 3, 2021, 18:28
Joseph
Oh, I should have thought about that. Thank you for pointing that out!
constant pressure, stagnation pressure
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 09:16
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
