Calculation Hidrodynamic & Aerodynamic Lift
Like Tree1Likes
  • 1 Post By ping
Old   January 4, 2021, 17:34
Default Calculation Hidrodynamic & Aerodynamic Lift
ali_Ebrahimi
ali_ebrahimi is on a distinguished road
Hi
I work in the field simulation CFD high speed planing in STAR CCM+.
I want to calculate Hydrodynamic & Aerodynamic Liftseparately in multiphase flow (water & Air).
Do you suggest a way to do this?
ali_ebrahimi is offline   Reply With Quote
Old   January 7, 2021, 06:46
Ping
ping is on a distinguished road
this is easy using a new threshold with the part surface you require forces measured on as the input part, the scalar field function set to the volume fraction of water or air, and the range 0,.5 or .5,1 depending on which field is chosen. this creates a new derived part which is a subset of the chosen input part and you do your force calcs on this new part
ping is offline   Reply With Quote
Old   January 8, 2021, 04:03
ali_Ebrahimi
I have done these processes before and the answer was not correct.
However, the sum of the aerodynamic and hydrodynamic lift forces calculated from the threshold will not be equal to the total lift force calculated from the part region.
I share photos of the settings made.
Old   January 8, 2021, 05:50
Ping
check the threshold parts in a geometry scene to make sure your threshold subsets of those surfaces are correct since it looks to me like you have used .05 instead of 0.5
ali_ebrahimi likes this.
cfd analysis, high speed planing, lift force, star ccm+
How to calculate lift, drag and lift distribution in Star CCM+? israelcasillas94 STAR-CCM+ 4 November 6, 2020 09:35
calculation of Lift problem imran99 FLUENT 0 April 9, 2015 07:37
Aerodynamic Force, analytical calculation punnag Main CFD Forum 0 December 31, 2014 17:45
Calculation of Lift nauman55 FLUENT 1 July 12, 2012 07:54
Warning 097- AB Siemens 6 November 15, 2004 05:41
