December 4, 2020, 00:59 |
STAR-CCM+ FWH Permeable Surface (CAA)
Rep Power: 5 |
Dear all,
I have simulated LES for supersonic jet flow. The computational domain is cylindrical and it includes the nozzle geometry. Currently, there is only 1 Region. I need to compute the jet noise in the far-field and therefore need to include a permeable FWH surface that encapsulates the noise sources in the exhaust (e.g. a conical shape that surrounds the jet flow), so that the FWH analogy can be used to propagate the noise sources into the far-field. Does anyone know how to construct a permeable FWH surface? Should I draw the FWH surface using the native 3D-CAD modeler or using New Shape Part (under Parts). Should the FWH surface be a separate region from my computational domain? (The FWH surface must be an "internal interface"). I have seen some tutorials (such as https://support.sw.siemens.com/en-US...ience=external) but they do not instruct on how to create a permeable FWH surface. You can have a look at the images attached (of my computational domain and instantaneous flow field). Your help is greatly appreciated! mnws |
December 24, 2020, 01:43 |
Rinia
Rep Power: 8 |
You need to split the computational domain into two pars. One part contains the noise sources and the rest domain is the other part. The interface between two parts is the permeable surface.
December 27, 2020, 22:26 |
Rep Power: 5 |
Dear Rinia,
Thank you for your reply. I'm currently trying that. |
December 30, 2020, 01:59 |
FWH surface
Rep Power: 5 |
Dear Rinia,
I constructed 2 regions, by subtracting a cone from a cylinder. The interface between the 2 regions, (which is the outer surface of the cone) is the FWH surface. This surface is meant to encapsulate all the noise sources from the turbulent eddies. As can be seen in the image attached (2 regions.jpg), the conical surface generated is not perfectly conical after meshing. I noticed that the native STAR-CCM+ mesher is able to preserve surface perimeters well for outer boundaries (as can be seen for the cylindrical outer boundary), but the inner conical surface resulting from the subtracted cone does not appear to have a good resolution. It appears slightly rough or crumpled. The cross section appears polygonal rather than circular. (FWH surface.jpg). Do you know how I can ensure that the conical shape is preserved? I have tried adjusting the parameters and tolerances for imprinting/subtracting etc. when preparing the regions but cannot improve the quality of the surface. |
January 3, 2021, 22:52 |
#5 | |
Rinia
Rep Power: 8 |
January 4, 2021, 21:38 |
Rep Power: 5 |
Thank you for the suggestion! Will give that a try.
May 23, 2024, 23:19 |
Rep Power: 5 |
Hi mnws, I've got same question with you, did you find more simple way to create permeable surface?
May 23, 2024, 23:26 |
#8 | |
Rep Power: 5 |
And you mean split into 2 parts, this operation can be done in starccm "edit in 3D CAD"?I'm stuck in this step. |
aeroacoustics, ffowcs-williams hawkings, star-ccm+ |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
Error while importing Solid Works Model into Star CCM | Sandy7 | STAR-CCM+ | 3 | December 19, 2016 11:21 |
Problem in PERIODIC BC in STAR CCM | mohammad | STAR-CCM+ | 7 | January 28, 2015 09:38 |
Fluent Vs Star CCM | firda | Main CFD Forum | 3 | February 26, 2011 02:51 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
