Non-Conformal Structured Meshing Via Directed Mesher |
November 10, 2020, 11:23 |
Christopher
Rep Power: 5 |
I am trying to create a 2D structured mesh for an aerospike nozzle on STAR CCM+ and so far am using a patch mesh through the Directed Mesh tool with Badge for 2D meshing. However, when selecting the patches in the streamwise direction (purple lines), I cannot find a way to create non-conformal boundaries between the patches, meaning that the mesh is far too fine in the region of quiescent air (bottom of image). I have attached an image of the domain in the patch mesher. The purple lines clearly show that if i wish to refine the mesh in the streamwise direction in the nozzle, this will occur uniformly in the entire y direction. Is it possible to create a non-conformal structured mesh where the cell faces touching at either side of the purple lines do not match up? Thanks, Chris Capture_Forum.PNG |
November 10, 2020, 19:57 |
#2 | |
Chaotic Water
Rep Power: 18 |
Also - keep in mind that Directed Mesher is a buggy piece of ***; once you change any size of any part even by 1 mm - it will delete all your patches and settings wailing that ".. topology has changed ...". |
November 11, 2020, 06:00 |
Christopher
Rep Power: 5 |
Thank you for your answer. To create this separate Directed Mesh Operation, am I right in saying I would need to create two separate parts and mesh them separately, then, create a boundary to join them?
November 11, 2020, 06:08 |
#4 | ||
Chaotic Water
Rep Power: 18 |
November 11, 2020, 06:37 |
Christopher
Rep Power: 5 |
Thank you for this
directed mesh, mesh 2d, non-conformal mesh, refinement, structured grid |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
structured and unstructured grids | user | Main CFD Forum | 6 | November 25, 2010 01:14 |
Flovent meshing - structured cartesian okay? | Josh Kjenner | Main CFD Forum | 1 | January 11, 2008 23:06 |
structured meshing | Rashmi | Main CFD Forum | 1 | December 6, 2005 19:12 |
structured meshing | Mavinakere | FLUENT | 4 | March 1, 2002 15:52 |
