April 1, 2020, 20:49 |
Periodic Boundary Conditions
Rep Power: 6 |
I am trying to set up a simulation something similar to the image attached. Basically there is a cuboid channel of fluid with an inlet and outlet and the 4 sides have periodic conditions. A model of a section of a grate / grill is in the centre. I am having trouble with the periodic BCs: despite setting them as periodic under interfaces, I am unsure what region boundary type to assign to them??Free stream, wall (with slip), or something else? This is my first time using periodic BCs in star-ccm+ so I just wanted to ask how the software treats these type of problems and if I need to modify my approach. Thanks in advance. |
April 2, 2020, 03:35 |
Ping
Rep Power: 20 |
the key to your issue is in the naming - they are called periodic interfaces and not BCs and are not actually boundary conditions in the star lexicon. once you interface the two sides successfully the boundary type you previously assigned is ignored. it is however important in the case of a partial interface eg on a sliding boundary
April 2, 2020, 07:31 |
#3 | |
Rep Power: 6 |
April 2, 2020, 17:22 |
Lucky
Rep Power: 66 |
That's fine. Sides can touch.
April 2, 2020, 19:21 |
Rep Power: 6 |
I've tried a couple of things, but still getting an output that the interfaces are not conformal (hence I assume the periodic BC failed).
I've tried setting the interfaces to be fully developed as well as internal, with a periodic type (translational). Should I be looking at contacts? Anything else? Thank you. |
April 3, 2020, 07:23 |
Ping
Rep Power: 20 |
conformal can refer to the surfaces used on either side not being identical in shape and area when the transformation is applied - so check your geometry is perfect or it could be if you are using surface repair or wrapping which can alter the geometry and should not be required for such simple geometry anyway
it can also apply to the mesh being conformal or the mesher having trouble achieving this feature |
April 3, 2020, 10:47 |
#7 | |
Rep Power: 6 |
boundaries condition, boundary condition, regions, simulation won't run |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 06:53 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
PEMFC module + multiple periodic boundary conditions | vkrastev | FLUENT | 2 | December 22, 2014 05:15 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
