Dynamic Ground Effect Simulations
Like Tree1Likes
  • 1 Post By me3840
Old   March 16, 2020, 07:16
Default Dynamic Ground Effect Simulations
James Permain
JamesPermain is on a distinguished road
I am hoping someone can help me with a possible way I may be able to define the position of my ground wall boundary relative to my 2D moving airfoil for which I want to simulate dynamic ground effect.
I am going to be running dynamic simulations for a NACA4412 airfoil under the influence of ground effect. I will be moving my airfoil in two ways during my simulations:
1) A constant pitch angle and constant sink rate approach to the ground
2) A varying pitch angle rotation at a given height above the ground
I need to define my airfoil's instantaneous height above the ground as the distance between the ground and its closest point to the ground. For angles above roughly 1 degree this is always the trailing edge, but for lower pitch angles this point of closest approach varies with pitch.
I therefore need a way to extract the minimum distance from my airfoil's geometry to the ground wall so that I can match values of lift and pitching moment to given heights.
If there was also a way to create a field function that I could plot/export that would be great, and if I could also use the field function as an input into the origin of my background (and thus wall boundary) I would be able to manually define heights for these tricky pitch angles based off the airfoil's geometry.
Any ideas on how I can do this are much appreciated! Please ask for any clarification if this post is not clear; it is my first one on this forum!
JamesPermain is offline   Reply With Quote
Old   March 19, 2020, 15:17
me3840 is on a distinguished road
Is this a transient simulation? If so you can easily define a coordinate system at the non-moving component and then evaluate the minimum of position (using a report) on the airfoil boundary. Recording that as a monitor will give you a plot of time vs height.
Steklo_Plastik likes this.
me3840 is offline   Reply With Quote
Old   March 20, 2020, 10:31
Chris
Chris2337 is on a distinguished road
I would also make the ground boundary a symmetry plane so it doesnt grow a boundary layer but does act like the ground.
Chris2337 is offline   Reply With Quote
Old   March 21, 2020, 09:00
James Permain
Yes these are transient simulations. This is exactly what I was looking for. I have implemented this and it's working just right. Thank you for your help.
Old   March 21, 2020, 09:02
James Permain
Thank you for your suggestion Chris. I have set the wall boundary to a slip condition under the shear stress condition so this should prevent the formation of a boundary layer anyway.
field function, geometry, ground effect
Ground Effect hk.narahari SU2 4 November 12, 2021 07:25
[ANSYS Meshing] Divide entire ground into sub sections for moving ground for vehicle aerodynamics CFD johny_walker ANSYS Meshing & Geometry 0 February 24, 2020 10:42
Ground effect on wing hk.narahari Main CFD Forum 1 September 13, 2019 04:52
[ICEM] meshing airfoil in ground effect cfd_peter ANSYS Meshing & Geometry 12 March 14, 2017 18:30
Ground effect in wings varies with turbulence models ?? redordead FLUENT 0 October 8, 2016 16:50
