Lift and Drag Coefficients Too High
Like Tree1Likes
  • 1 Post By fluid23
Old   September 27, 2019, 16:44
Default Lift and Drag Coefficients Too High
Stephen
SteveFRUCD is on a distinguished road
First post here, I've been having trouble getting reliable coefficients out of both 2D and 3D sims. I've been testing a simple NACA E591 airfoil to compare results to the database, and I'm seeing drag coefficients of .863 and lift of 60.3 when using an alpha of 0 at Reynolds of about 500,000. Strangely, the ratio between them is a little low but believable (~70). Also, I used the lift and drag forces from the 3D sim to calculate the coefficients by hand and they came out to .633 and .0367 which is far more believable, even with the drag being high. Am I using the coefficient reports tool incorrectly? Any help would be greatly appreciated!
SteveFRUCD is offline   Reply With Quote
Old   September 30, 2019, 10:27
Matt
fluid23 is on a distinguished road
The coefficient reports can do some weird things. I have contacted the support staff about it in the past thinking it was a bug, but was informed that it was intentional. Basically, when calculating 2D coefficients, the reference area assumes a depth of 1m regardless of your unit system. For example:
1.8315m (chord length) x 1m (depth) = A for SI
or
6ft (chord length) x ‪3.28084ft (depth) = A for BG
I am not sure that will solve all of your problems, but it might help. You should also confirm the reference density and speed in the coefficient match your setup, use wake refinement options and conduct a mesh dependency study (if you haven't already).
Chris2337 likes this.
fluid23 is offline   Reply With Quote
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 07:04
How to not overwrite drag and lift coefficients after a simulation Giovanni Trovato FLUENT 1 August 1, 2018 01:31
Lift and drag coefficients of the NACA 0018 Volodymyr CONVERGE 4 September 22, 2017 18:52
Lift and Drag coefficients for flow past sphere shashanktiwari619 FLUENT 0 January 27, 2017 14:31
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 15:45
