September 25, 2019, 04:36 |
Transient simulation with initial solution
Rep Power: 14 |
Good morning , i need help with a simulation . I must to simulate a freezer with some trays with water inside of these. Now i did a simulation in stationary where i calculate the tubulent model and the corret flow rate from fan , with the drop pressure. In this case i would take the solver solution for another simulation in transient , because i must understand which is the tray that 'll arrive to -20°C with change of fase from liquid to solid. In your opinion is it possible ? and i wonder if are there someone that could tell me how. Thanks for the response
September 27, 2019, 12:05 |
Matt
Rep Power: 18 |
Can you rephrase your question. I have no idea what you are asking.
October 2, 2019, 15:44 |
#3 | |
Rep Power: 14 |
later I changed the physics to implicit unseady. So my question was : it is possible to fry the viscosity solver, the turbulence solver and the flow solver, and get the right results? in any case, I am currently developing the simulation in implicit unsteady, without freeing the solver , but I don't understand why the temperature of the water decreases slowly, although it supplies a considerable amount of energy to the air that cools it. i use this physics: Air: implicit unsteady two layer all y+ wall treatment Exact wall distance realizable k epsilon two layer K epsilon turbulance Reynolds averanged Turbulent Segregated fluid temperature ideal gas Gradients Segregated flow Gas Three dimensional Water: implicit unsteady Segregated multifase temperature Two layer all y+ wall treatment Exact wall distance realizable k epsilon two layer K epsilon turbulance Reynolds averanged Turbulent Gradients Segregated flow Multiphase equation of state VOF multiphase interaction Eulerian multphase Three dimensional In your opinion there is some error? |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 18:36 |
Wrong fluctuation of pressure in transient simulation | caitao | OpenFOAM Running, Solving & CFD | 2 | March 5, 2015 22:33 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 13:50 |
