September 13, 2019, 01:35 |
Underprediction of Lift Coefficient-NACA0012
Rep Power: 14 |
1. I have been trying to estimate CL and CD of NACA0012 airfoil. I am constantly getting an underprediction of CL by around 19%. The Reynolds number I am working on is 4.0E5. Details of the setup are as follows:- (a) 3D Steady in water (b) Polyhderal and Prismlayer mesher (c) SST-menter K-w turbulence model. Wall Y+ after simulation is attached. 2. I am unable to understand what I am missing. Is it the mesh? The number of cells is around 1.4 million. 3. Convergence happens without any issues. Further, in SST Menter-K-w model, do we need to activate the low Re damping factor for this case? The starccm manual says only for transitional flows that action needs to be undertakenPrism Layer.jpg Prism Layer.jpg Wing_AOA4_Mesh Scene 1.jpg Wing_AOA4_Mesh Scene 2.jpg Wing_AOA4_XY Plot 1.jpg |
September 13, 2019, 10:26 |
Matt
Rep Power: 18 |
your mesh is definitely not appropriate. look into wake refinement and conduct a mesh dependency study before determining that your converged result is the best you can do.
September 14, 2019, 06:07 |
Wake Refinement
Rep Power: 14 |
Hello Matt,
1. Thank you very much for your suggestion. 2. Since the polyhedral meshing model doesn't have a wake refinement option, I incorporated a volumetric control. However, the drag result looks nice but CL is still being underpredicted. 3. I have set the extents of volumetric control based on the scalar view of velocity. Is there anything else I should incorporate in such cases? |
September 16, 2019, 10:03 |
Matt
Rep Power: 18 |
The polyhedral mesher absolutely does have wake refinement options. A volumetric control is probably not the best way to approach that. Refer to the Star-CCM help files:
Pre-Processing > Meshing > Custom Mesh Controls > Mesh Refinement in a Wake After that, make sure to do a mesh dependency study. Once you are confident that your result is independent of the spatial discritezation (i.e. your mesh), then you can assess whether your values are 'correct'. |
September 16, 2019, 15:52 |
Chaotic Water
Rep Power: 18 |
You also can a Table-based Mesh Refinement.
November 13, 2019, 19:23 |
Chris
Rep Power: 7 |
The polyhedral only has wake refinement in parts-based meshing, so if you're using region-based meshing, like you would for the trimmer 2D, then switch to parts-based.
November 14, 2019, 14:38 |
Paul Hancock
Rep Power: 17 |
Adaptive mesh refinement should be WAY easier than it is in CCM+, but . . . .
Consider taking a look at the STEVE article I'm hyperlinking below. It might give you some ideas on how to tweak your mesh to get the best predicted lift you can: https://thesteveportal.plm.automatio...pturing-shocks |
November 14, 2019, 14:46 |
#8 | |
Chaotic Water
Rep Power: 18 |
1) Define where, why (∇P, ∇T, Turbulent Viscosity Ratio etc) and how the mesh should be refined via Field Function. 2) Extract Field Function to a table. 3) Mesh according to the table. Since not everyone has constant access to the Steve Portal - here is a video on youtube: Table Based Refinement in STAR-CCM+ |
starccm+ naca0012 mesh |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 07:04 |
CFX/Fluent- Underprediction of Lift Coeffcient in 2D Airfoil Simulation | DanielBarreiro | Main CFD Forum | 4 | September 2, 2021 03:16 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 06:18 |
Lift coefficient in Eulerian multiphase model | hennas | FLUENT | 1 | July 4, 2011 17:50 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
