Very high pressure coefficients on a wind turbine blade
Like Tree1Likes
  • 1 Post By me3840
Old   July 12, 2019, 08:34
Exclamation Very high pressure coefficients on a wind turbine blade
Soroush Kargar
Seervan is on a distinguished road
Hi all
I am modelling a wind turbine rotor with an RPM of 72 and diameter of 10m. The inlet velocity is 5 m/s. I am using MRF in steady state. While I extract the torque my results agree with the experiments of the literature. However, when I extract the pressure coefficient I get values of -3000~2000! It is pretty odd to me and I need the pressure coefficients. I have played with mesh, change my physics from incompressible to compressible cte density and yet the problem exists. Do you have any suggestions? What part can me wrong? I am using k-w sst and tried both polyhedral and trimmer meshers.
Thanks in advance
Seervan is offline   Reply With Quote
Old   July 12, 2019, 21:19
me3840 is on a distinguished road
Are you sure the Cp reference values are set correctly?
me3840 is offline   Reply With Quote
Old   July 13, 2019, 02:34
Soroush Kargar
I am using the default "Pressure Coefficient" field function. I don't know about its reference values. Maybe I should define a field function based on two extracted static and stagnation pressure points?
Old   July 13, 2019, 14:52
The computer can't set the reference values for you, there is no such thing as a default pressure coefficient. You need to go to tools>field functions>pressure coefficient and set the reference values.
Seervan likes this.
FSI simulation of wind turbine blade using NLH method Ko_Shine Fidelity CFD 3 April 22, 2020 08:08
Fluent: Proper Solver for Pressure ratio in high pressure turbine lotd ANSYS 0 September 20, 2018 03:00
wind turbine blade flow simulation rsskarthikeyan FLUENT 0 May 27, 2015 06:40
Modelling of 2D Wind Turbine Blade (HAWT) Richeom FLUENT 1 August 11, 2010 05:18
Wind Turbine Blade Geometry SeanieB Main CFD Forum 0 November 27, 2009 11:18
