Pierce
Rep Power: 7 ![]() |
I'm trying to run an aerofoil under inviscid flow conditions, however, when selecting the viscous regime to Inviscid, my solver fails to converge. This is a simple simulation with M=0.3. I know it is often discussed that you set flow to laminar and free slip, but this is not a truly inviscid simulation. Has anyone got experience with this?
Matt
Rep Power: 17 ![]() |
I believe that that the discretization of the Euler equations results in numerical diffusion/artificial viscosity. I don't have personal experience with this, but you might try changing the differencing scheme and/or order of the discretzation.
I did a little reading on Steve portal and it sounds like steady solutions are limited to up-wind scheme. You mgiht have to employ a transient solver to get different schemes. There are several options. https://thesteveportal.plm.automatio...ed-in-STAR-CCM |
euler equation, euler flow, inviscid flow |
Question about Euler solver for incompressible flow | qtian | OpenFOAM Running, Solving & CFD | 3 | March 27, 2018 05:34 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Gate valve flow simulations... | nikesh | FloEFD, FloWorks & FloTHERM | 5 | January 28, 2014 01:31 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 04:55 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
