Modeling Cryogenic Tank with VOF
Like Tree2Likes
  • 2 Post By jpesich
Old   March 13, 2019, 12:31
Default Modeling Cryogenic Tank with VOF
Justin
jpesich is on a distinguished road
I am modeling a cryogenic storage tank with saturated liquid/saturated vapor hydrogen. It's a spherical tank so I am using 2D axisymmetric, laminar, VOF solver. All second order schemes except 1st order time stepping. My initial conditions are T=20K and P=saturation pressure at 20K, zero velocity. Gravity is at 1g. The tank is halfway filled with liquid.
My only boundary condition is ~0.6mW uniform heat source on the tank wall.
I have constant material properties except ideal gas for vapor phase and polynomial in T for liquid phase. The expected change in temperature is very small.
My temperature contours look as expected but the flow structures around the axis boundary condition are not expected at all. I would expect the flow to rise up to the surface and fall down the middle (in the direction of gravity). Am I off base on this? My courant number at the interface is <0.7. I have not adjusted any values except applying a phase interaction and momentum interface damping. This should not affect anything near the axis except at the interface.
jpesich is offline   Reply With Quote
Old   October 23, 2019, 19:18
reino is on a distinguished road
I'm attempting to simulate a very similar problem for a school project (but with LN2) and I'm facing convergence issues. Would it be possible to have some additional information on how you achieved the shared results (namely the phase interaction models and solver parameters) ? As I'm pretty stuck (and for some time now), any additional information you could share would be of great help.
Thank you.
reino is offline   Reply With Quote
Old   October 23, 2019, 19:42
Justin
This post was actually the inception of finding a bug in the STAR-CCM+ code. Only for 2D axisymmetric problems where the axis intersects a wall boundary, a spurious pressure gradient appears near the intersection of the two boundaries. Currently, the code is unable to solve axisymmetric problems other than ones with an inlet and outlet and each end.
I have been collaborating with them and they have shown me results proving the bug is fixed. The version with the bug fix will be tentatively released in February 2020.
cwl and reino like this.
Old   October 23, 2019, 20:07
cwl
Chaotic Water
cwl is on a distinguished road
Thank you jpesich for that important note!
cwl is offline   Reply With Quote
Freesurface Modeling with VOF method mohammadizadi STAR-CCM+ 0 August 21, 2018 04:22
Pressure Temperature Evolution in Tank Venting by VOF model-FLUENT avi@lpsc Main CFD Forum 0 August 4, 2014 07:25
Is it possible to simulate tank filling process in 2D (VOF Model)? Blue FLUENT 0 November 30, 2013 13:47
advice for modeling water tank ryan_c OpenFOAM Running, Solving & CFD 1 November 15, 2012 17:42
modeling bumping a tank Will Fitzgerald Main CFD Forum 1 January 5, 2000 18:15
