Cannot Figure Out How to Transform Part Surface to Derived Part |
December 1, 2018, 23:05 |
PA
Rep Power: 8 |
I've created a specifically contoured plane CAD. I'm aiming to transform it to a derived part in StarCCM from which I can then extract mass flow data from. I can't figure out how to tell StarCCM to do this: Any help is appreciated |
December 2, 2018, 22:32 |
Rep Power: 25 |
You can export the surface as an STL and use an arbitrary surface to compute the mass flow.
However I would not recommend this, as using a section that is not in the mesh will not be conservative. If you want to measure mass flow you should put the interface in the mesh. |
derived parts, starccm+ |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 02:10 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
Postprocessing in 3d - Creating part of a surface | shankara.2 | FLUENT | 0 | July 13, 2009 18:33 |
