Imposed vibration on a pipe with flow
Like Tree2Likes
  • 1 Post By Ubuntu
  • 1 Post By Ubuntu
Old   August 22, 2018, 14:09
Smile Imposed vibration on a pipe with flow
Fernando Santos
FSantoX is on a distinguished road
Hey guys
I need to simulate a flow inside a pipe, but with the pipe vibrating in a manner that the channel opens and closes. The vibration is prescribed, I'm only interested in the effects on the fluid, not on the solid.
I wanted to know if it is possible on Star-CCM+. Also, the solid displacament should be very big, and I have no idea how that behaves with the mesh in a fluid simulation, regardless of the software.
Thing is, I can't find anything similar to that on the documentation. The closest one is the FSI tutorial, which doesn't really answer my question.
FSantoX is offline   Reply With Quote
Old   August 23, 2018, 01:31
Default Hi
Ubuntu's Avatar
Siddharth
Ubuntu is on a distinguished road
Hi Fernando,
Do you have any pictures showing the motion of the pipe?
Are there any equations for the motion? (since you said you are imposing the motion on the pipe)
I may be able to help you.
Ubuntu is offline   Reply With Quote
Old   August 23, 2018, 13:28
Fernando Santos
Originally Posted by Ubuntu View Post
Hi Fernando,
Hello Siddharth
Thank you for your reply.
I made a quick sketch:https://imgur.com/0i3aiid
It's that, but in 3D. It is a circular pipe. That's not the complete domain, there is more, but that's the part I'm interested in discussing.
As for the movement, I would be using a table of values. I have the area ratio values with time, but not a time function.
Old   August 23, 2018, 21:58
Default Mesh morphing?
Ubuntu's Avatar
Siddharth
Originally Posted by FSantoX View Post
Hello Siddharth
Based on this figure, I can suggest morphing motion in Star CCM+. I think there is a tutorial in User guide related to this.
Hello Siddharth
It can read table values and use for boundary conditions.
Hope this helps.
ashokac7 likes this.
Old   August 24, 2018, 13:16
Fernando Santos
Hope this helps.
I'll check this morphing motion today. I hadn't seen that term yet, but the name seems to imply exactly what I need.
I was already using tables, but for different boundary conditions. I just hope the table that I have will work with this condition.
One last question. With this problem, I need for the geometry to close off completely, but I think that could cause numerical issues. I've never worked with fluid-structure interaction before, but I've seen some papers that would not completely block the flow when solids were movind through the fluid. Can you tell me if it is possible to solve something like this? Or should I try to leave some minumum opening?
Old   August 24, 2018, 22:04
Ubuntu's Avatar
Siddharth
I agree with you. I think that an attempt to close it completely will cause problems. The "negative volume error" is a usual one in case of morphing motion.
In my opinion it would be better to go for a minimum opening rather than trying to close it completely when you are using mesh morphing.
Also I have seen some videos (https://www.youtube.com/watch?v=RYKolUSipLQ) related overset meshing in Star CCM+ where it is possible to close the flow path completely. You can explore them too.
Hope this helps.
channel flow, fluid-structure, incompressible
Pipe flow with obstacle - HELP Min FLUENT 6 January 31, 2017 15:28
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 22:25
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 12, 2012 00:18
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 21:41
Pipe Flow Saima CFX 1 January 10, 2011 17:41
